those were black before i painted them that gunmetal which is a mix of dark ford alloy and honda vogue silver with a bunch of clear. the stock paint on the nurburgring is absolute trash. very thin single stage
the tires are 265 35 18 and 295 30 19 michelin pss
i tried the 305 30 19 first and they look absolutely retarded on the 10.5" wheel. porsche specs that tire on an 11.5-12" wheel and i quickly found out why
this is the 305 on rear, see what i mean. they hang over a solid 3/8" the 305 in pss is just ridiculously wide
also won't clear the rear brake ducts without 5mm spacers {which aren't a bad idea to run anyway since the rears are cast at 65mm}
the 295 30 19 and 265 35 18 combo is spectacular. the car is very neutral, comes back easily and behaves very well. i absolutely LOVE this tire as street tires go. it performs well without needing heat in it and rails in the rain. does everything a street tire should and gets even better if you do put some heat in them.
Awesome, thank you very much for the info. I'm torn on whether I want to do the Nurburgrings or stock c5z.
