I attempted to install the harness that keeps the lowbeams on when the high beams are turned on. I've not had any success with the harness I received. Has anyone else here installed that harness, and what kind of luck did you have? The vender (a forum supporter)does not take phone calls and only works off E-mail. I'm going to install the high beam HID's (already have lows) and I want this mod to work before proceeding.
Installed on mine a while back and worked perfectly. I don't have HIDs though. Not sure if that had anything to do with it or not but it was seamless. No issues.
I used the JWMotoring Four-On harness. I installed it per the instructions in about 15 minutes and it has worked as advertised. I do have to check and occasionally retighten the ground connection, but that's not an issue with the harness.
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I sent him some things to check. If it doesn't work we'll replace it or refund him for it. We make them in house and stand behind them 100%
After some trouble shooting, it appears there is some kind of short in the relay socket and JW is sending me a new unit. It should arrive this week. He did not hesitate, once we figured out where the problem lies.
