Creeking Top
Old Oct 26, 2013 | 12:11 AM
storxusmc's Avatar
storxusmc
Default Creeking Top
I have been checking out the market on C6's and C5's and of all the cars i have test drove. Wow do the tops make alot of noise. Is there a way to get around this? Or is this something you just got to deal with owning the car. The 2007 i drove today had those see through plexi glass tops and it was so annoying i turned around and took it back.. dealer asked why i cut the test drive so short and i said i was highly annoyed by the noise it made from every little bump..
Old Oct 26, 2013 | 05:16 AM
Dinger's Avatar
Dinger
I have a '97 that would squeak and rattle. The factory repair manual tells you how to adjust to eliminate the squeaks and rattles by re-aligning the mounting hardware. Mine is nice and quiet now.
Old Oct 26, 2013 | 05:22 AM
As mentioned above, there are some adjustments that can be made to make the tops fit tighter on the car. I have a few Word files that talk about the targa adjustments on the C5 and if you'd like a copy of them, just PM me your e-mail address.
My '03 does not rattle or squeak at all. Good luck finding a car BTW.
Old Oct 26, 2013 | 05:24 AM
Outlawtorn's Avatar
Outlawtorn
If you buy a coupe with a removable roof, you can expect wind noise and some creaking. The wind noise will never totally go away, but if there's creaking, you can eliminate that by thinly applying dielectric silicone grease to the weather-stripping. It also prevents cracking, so do this to all weather-stripping, on any car.
Old Oct 26, 2013 | 09:35 AM
Fcar 98's Avatar
Fcar 98
On the windshield were the latch locks. There are little rollers. Mine were frozen, some 3 in 1 oil worked them lose.
Old Oct 26, 2013 | 09:38 AM
CactusCat's Avatar
CactusCat
You can also adjust the tightness of the center latch at the rear of the targa roof.
Old Oct 26, 2013 | 10:08 AM
CQRT's Avatar
CQRT
I lube the latches with WD40 . . . and then run my fixer around the weatherstripping with a very light coating of white lithium grease . . it doesn't attract dirt and quits the roof down for awhile . . .
Old Oct 26, 2013 | 02:08 PM
DanSavage's Avatar
DanSavage
Originally Posted by storxusmc
I have been checking out the market on C6's and C5's and of all the cars i have test drove. Wow do the tops make alot of noise...
Reminds me of an old joke.
Q: Do you what is the loudest noise in the world?
A: The first squeak in a new car...
Old Oct 26, 2013 | 02:27 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
When mine made noise I just adjusted the front 2 latches, What I did was lower the part on the windshield maybe 1/32 of an inch and it took care of the noise, There are 2 10mm bolts you have to loosen up and then tap the mount down just a tiny bit and them tighten them back up and test drive.
Old Nov 5, 2013 | 05:00 PM
PUTKA's Avatar
PUTKA
6th Gear
As a new owner of a 2002 coupe the roof noise drives me crazy. I would like more information on how to adjust the roof. gpelescak@roadrunner.com
Old Nov 5, 2013 | 05:42 PM
Fcar 98's Avatar
Fcar 98
I would be careful to adjust a glass top. It may stress the top.
Old Nov 5, 2013 | 06:58 PM
coia96vette's Avatar
coia96vette
I have both tops for my 04 and have no squeaks at all. Just adjust them and be done with the noise.
Old Nov 5, 2013 | 08:40 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
PM sent
Old Nov 5, 2013 | 09:47 PM
o2bnkc's Avatar
o2bnkc
You'd really hate driving a c4 then!
Old Nov 6, 2013 | 01:19 PM
PUTKA's Avatar
PUTKA
6th Gear
How do you adjust the square latch on the rear of the roof of a 2002 coupe? I see that some are a round bolt with a nut, mine is square and can not be screwed in or out.
Old Nov 6, 2013 | 05:27 PM
CactusCat's Avatar
CactusCat
If I remember correctly, when I adjusted mine, I loosened the nut and then you use an allen wrench to adjust the latch. Then tighten the nut back up when you're happy with the fit.
Old Nov 6, 2013 | 06:42 PM
dcandel's Avatar
dcandel
Oldtimer
Cut up an old credit card into 2 pieces about 1/4" X1". Unlatch both front latches. Place a piece of the cut up credit card between the roller and close the latch. Do the same for the other side. No noise or squeeking. It's good for about a year or so.
To Creeking Top
