this always made me wonder....if a c5 coupe and a c5 Z went on a head to head race straight line and or track course... which would come out faster?... heres the catch , both are modded equally the same.. suspension to all bolt ons including HCI and driven by same driver.
I don't think I really understand.... 2 identical cars should perform the same. However providing all suspension, bolt-ons, gears the whole lot are identical then the only real judgement factors would be curb weight, drag coefficient and tire size/type.
Z06 being lighter with larger OEM tire sizes, and Coupe being more slippery. If that helps at all
Providing all suspension, bolt-ons, gears the whole lot are identical then the only two real judgement factors would be curb weight, drag coefficient and tire size/type.
what if tires were same size and brand, but gearing is stock... is there a lot of difference between the z gearing and coupe?
The Z should win. To answer your question on the gearing, a manual tranny car in either model has a 3.42 rear end, but the transmission ratios are different between the coupe and Z.
I had a 01 Z once and I have a slightly modified 01 coupe now. God I wish I had the Z back. The Z just stands by itself.
Same here. Had a 2000 coupe before and currently have an '03 z. I've had both on the track in stock trim and the z wins hands down. That being said, I do miss being able to take the targa off
Targa top is a great bonus to the coupe. It's my wife's favorite part, but the coupe just feels heavier. The Z just as a whip ability if you know what I mean. I use to love getting the rear end loose around the corners. The coupe doesn't have that same feel, but I still love it.
I've had both as well.
I had a 98 coupe with lots of mods and HP well in excess of my current cam and Bolt-ons 03 Z. The Z is just a snappier, better planted package. Even beyond the mechanical differences, the car gives you more feedback and instills more confidence.
once modding begins all bets are off.. but the Z is WAYYYY faster out of the box. period
The OP stated equal mods, so handling and power should all be pretty much the same. That leaves aerodynamics. As you can see from the pic above, Chevy chose the coupe to go racing.
My car has C6Z suspension bits all around, and with 500 wfpt I don't really care whether I have closer gear ratios or not.
