C5 408 Oil Capacity
Old Nov 2, 2013 | 10:11 AM
animuL's Avatar
animuL
Default C5 408 Oil Capacity
I'm just about to put oil in my 408 for the first time but I am curious what is the correct amount of oil for it? Is it the same as the LS1 or is it somehow different for the new iron 6.0L block? It has the stock 98 oil pan and nothing that I believe should change the factory recommended amount but I just want to be sure. Anyone know?
Old Nov 2, 2013 | 10:16 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
If the oil pan is the same as factory; the quantity of oil will be the same. Refill with the Factory amount, then check the level and add more if needed.
Old Nov 2, 2013 | 11:54 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
If it has the 98's pan then it is still 6.5 quarts of oil to fill to capacity!
Nothing changes and do not over fill or you risk loosing an oil seal!
Thanks,Matt
Old Nov 2, 2013 | 11:55 AM
madmatt9471
Sorry meant 6.5 quarts not 6.6 quarts!
Thanks,Matt
Old Nov 2, 2013 | 05:02 PM
animuL's Avatar
animuL
Thanks guys!!
To C5 408 Oil Capacity
