[Z06] What size spacer in rear for a base C6 wheel
Old 11-05-2013, 11:43 PM
doveboat
doveboat's Avatar
Default What size spacer in rear for a base C6 wheel
I have stock 2008 split spoke rear wheels that I want to use in the rear of my stock C5 Z with factory rear brake ducts.
What size spacer will provide clearance for the brake duct ?
Thanks,
Ed
Old 11-06-2013, 09:36 PM
doveboat
doveboat's Avatar
Any thgts on picking up some 1/8" washers to measure out what size is needed ?
My gut tells my 1/4" should meet my needs and allow me to use stock length studs.
Ed
Old 11-07-2013, 01:28 AM
skyavonee
skyavonee's Avatar
Ed
The washers idea sounds like a decent plan to me. Since you have both the C6 and C5Z06 wheels in your possession, can't you take some measurements to compare the offsets?
Old 11-07-2013, 09:42 AM
doveboat
doveboat's Avatar
Was hoping someone here has done this before and could confirm that a 1/4" spacer will work with current studs.
I attempted to mount up a rear C6 Wheel before and it slightly rubbed on the rear brake duct.
I will confirm and report back to the community.
Ed
To What size spacer in rear for a base C6 wheel
Quick Reply: [Z06] What size spacer in rear for a base C6 wheel
