a battery question
Old Nov 20, 2013 | 08:21 PM
jlbsam's Avatar
jlbsam
Default a battery question
Maybe someone can educate me about my battery. its a Delco OE style battery, almost 3 yrs. old. after i drive the car for awhile and then let it sit for a couple of hours, the voltage i get with a digital multi-meter is right at 12.5. my research says that means about 85% charged. I would think it should be higher than that. Any advice?
Old Nov 20, 2013 | 08:39 PM
jlbsam's Avatar
jlbsam
i had not disconnected the negative terminal, but i just went out and did that, and the same reading - 12.5
Old Nov 20, 2013 | 09:21 PM
jlbsam's Avatar
jlbsam
the past week, i have used my charger for 2-3 hours at a time and driven the car a couple of hours, and i haven't had a voltage reading above 12.5. i think my battery is on the way out!
Old Nov 20, 2013 | 09:38 PM
bobby777's Avatar
bobby777
You can check a battery anytime--hooked up or not as long it has not been on any charger/maintainer for 12 hours--the reading will be right on-
Old Nov 20, 2013 | 11:03 PM
thisMSGgood4me's Avatar
thisMSGgood4me
Hey here's a crazy idea...take it to a place that sells batteries and have it load-tested. Then you'll know for sure whether it's on the way out or not.
Old Nov 20, 2013 | 11:36 PM
El original's Avatar
El original
Old Nov 21, 2013 | 12:01 AM
cramar's Avatar
cramar
For sure testing it would be ideal, but I had a similar situation with a battery being low all the time since the car sits for weeks and doesn't get charged up enough with occasional driving. I bought a NOCO Genius charger, but it wouldn't charge up the battery enough. When I called their technical support, I was told that my battery was on the way out. Figuring they were full of it and the NOCO was not hitting the battery hard enough, I connected a higher voltage charger for a few hours, then bought a Battery Tender Jr. as a maintainer. Now the vette is under constant charge and the battery is maintained at 13.10. Seems as good as new now. Bottom line, before giving up on the battery, I'd charge it hard for a day then use a maintainer on it if not being driven often.
Old Nov 21, 2013 | 12:58 AM
JETninja's Avatar
JETninja
WA Events Coordinator
That's why I only use a smart charger...a CTEK 4.3 from DDmods...keep it hooked up all winter and when I don't drive it for weeks.
I know most younger folks don't know, but you can still find "gravity" cell measuring tools, they suck up some of the fluid from a cell and the colored ***** float depending on the condition of the cell. Its a cheap and full proof way to check out each cell. But explaining it to a kid behind the counter at a autoparts place is like talking physics to them.
Old Nov 21, 2013 | 11:04 AM
Louthedog1's Avatar
Louthedog1
Old Nov 22, 2013 | 02:46 PM
jlbsam's Avatar
jlbsam
got up early this morning and went to O'Reilys and had it load tested. it was "tired", so got a new one!
To a battery question
