new vette co-owner
Old Nov 21, 2013 | 10:41 PM
james,fullyloaded's Avatar
james,fullyloaded
3rd Gear
Default new vette co-owner
recently i purchased a c5 convertable cherry red for my father who has wanted a vette since 1995, i was only able to come by this vehicle because it came up for bid by a county auction. she is running in good generally, but there is a number of things needing repair such as the passenger side door which is unresponsive. i have checked the fuses and even replaced the control module but it is still dead, and while i'm stuck waiting for the title and registration of the vehicle, anyone have any ideas? i have been told that only option left is the wiring, but hopefully someone out there has a better knowledge of this??
Old Nov 21, 2013 | 11:09 PM
JaxEagle's Avatar
JaxEagle
Depending on the year, you car is either Magnetic Red, Anniversary Red or possibly Carmine Red.
Old Nov 21, 2013 | 11:33 PM
El original's Avatar
El original
Congratulations on your purchase. Now to answer a question we all have to understand the question. What is unresponsive? (Sorry about being such a stickler on such formalities, lol)
Old Nov 21, 2013 | 11:53 PM
james,fullyloaded
3rd Gear
Neither the window or the door lock will work. It is a 2004 convertible.
Old Nov 22, 2013 | 12:00 AM
james,fullyloaded
3rd Gear
To be more precise door lock works manually but will not work electrically from driver side or passenger side or remote. Yes I guess I will be needing the color for when I replace the front bumper cover.
Old Nov 22, 2013 | 05:47 AM
65GGvert's Avatar
65GGvert
What about Torch Red?
Old Nov 22, 2013 | 06:49 AM
Cutlassmaster's Avatar
Cutlassmaster
Check the wires in the rubber wire boot between the door and body. You can pull it out enough to disconnect and then reconnect. It could be disconnected or the actual terminals inside the connector are not tight when slid together. Have you checked with a multimeter at the connections for the control modules? Check that out and then get back to us.
GL
Chris
To new vette co-owner
