I would disconnect the battery and not get a replacement until you are ready to drive the car again. Others may disagree but I would NOT leave a dead battery (if that is what you have) connected to the car all winter. JMHO
A lot of people take the battery out for the Winter. So why buy a battery just to have it sit for 5+ months? Put it in in the Spring... maybe you'll catch a good sale before you put it back on the road.
leave the old one in ( assuming it will maintain a charge with the maintainer applied) and get a new one in spring.
Bad idea to leave a bad battery in a car for extended period with a battery tender. You are asking for trouble. Best thing is to pull it out and buy a new one in the spring.
Looks like the consensus is to take the battery out and put a new one in a new one come Spring.
Other than turning off the security on the radio (Don't know what that is read it somewhere.) is there anything else to do before the battery comes out to prevent any issues when the weather breaks ?
Have you had the battery tested? Is the alternator working OK? I would get the car to a reputable auto repair shop and have the charging system tested. The shop will charge the battery first then run a load test on the battery. They will also check the alternator to see if it's working correctly.
IF the battery fails a load test, then I would get another battery installed. You should still use a good quality battery maintainer to insure the new battery is always fully charged. i
Another test that should be performed is to see what the current draw is with the car sitting. If there is a current draw that's above normal and it's not fixed, getting a new battery will only cause it to gradually lose a charge if you don't always have it on a tender.
Thanks for the info !!
Yes I plan on having it tested before I replace it. It looks like the original battery and the "eye" is Black so I'm assuming................. You know what they say about assuming. LOL
If he is putting it away for storage, the best thing to do is leave the battery out and get a new one next spring. There is no good reason to buy a new battery now and put it in if he isn't going to run it for 3-4 months. Do the checks in the spring with a fresh new battery.
Either way you really should have a battery in the car. In case of a house fire (God forbid!) you might have enough time to rescue your vette.
...and if the dead battery freezes and the case cracks sending acid down into the cars electronics? Does insurance cover the thousands of dollars to fix that? Leaving a bad battery in the car for months at a time is bad advice.
A fully charged battery should not freeze even with temps below zero. A maintainer will insure a full charge and help keep the electrolyte from freezing.
And if the car is stored inside, the comment about being able to start the car in an emergency such as a fire pretty much says keep the battery hooked up.
I usually don't use my C5 in the winter and the car will sit for a good 4 months. I have a Deltran Battery Tender hooked up all the time and the 4 year old Interstate battery is in excellent shape.
He has a bad battery. He is putting the car away for the winter. The best thing to do is pull the battery out and get a new one in the spring. Do not leave the old battery in the car. Even the owners manual states for storage longer than 3 weeks disconnect the battery. In case of fire a car is not the most important thing to worry about. It is insured.
No way I'd leave a car sitting in my garage all winter with no battery. I'd put a new battery in and connect a float charger. You never know when you might want or need to move the car quickly. If it's stored somewhere I can't get to it anyway, that's different.
You have a problem with fires at your house? When you put a car away for long term storage the battery should be removed. It is the recommended procedure. If you plan on starting it or driving it once in a while then by all means leave a battery in it. Of course that does make it easier to steal.
