putting vette on jack stands
Old Nov 25, 2013 | 08:00 PM
hmmmm16417's Avatar
hmmmm16417
Default putting vette on jack stands
I did this rhe other day and thought it was a huge PITA! The tires are about 10" off the ground so over the winter I can crawl under and do "stuff" and maybe get tires changed ....check brakes, clean, etc
Im going to have to find an easier way to let it back down because it doesn't seem safe using one jack, one end at a time.
Also.....three of the 4 jack stands are making contact. ...the fourth is almost 1/4" off. Assuming my floor is slightly off.
Old Nov 25, 2013 | 08:19 PM
corv1998's Avatar
corv1998
Its not so bad when you just go up a few inches at a time. I went to home depot and bought a few 8 foot 2x10 planks and cut them into 2 foot pieces. Jack a little , place blocks under tires , then other end same thing ,till you reach desired height. I always try to double support car when under it ,meaning jack stands and blocks under tires or under crossmembers if tires are off, better to be extra safe
Old Nov 25, 2013 | 09:07 PM
momo20's Avatar
momo20
now for your next goal, try changing out your transmission with only using jack stands
Old Nov 25, 2013 | 09:10 PM
James2002z06's Avatar
James2002z06
Default Dam....
I bet that was a pain in the azz
Old Nov 25, 2013 | 09:13 PM
hmmmm16417's Avatar
hmmmm16417
Lol. ..not a chance.
Old Nov 26, 2013 | 09:19 AM
camburger's Avatar
camburger
Jacked mine up only once in three years...that was to fix those GD rubber air dams. It's a total PIA for sure...
Old Nov 26, 2013 | 10:13 AM
slvr bulit's Avatar
slvr bulit
Changed my clutch on jackstands last year!
Old Nov 26, 2013 | 10:16 AM
envyz06's Avatar
envyz06
You sir are brave to do that on only jack stands!
Old Nov 26, 2013 | 10:19 AM
Coach32's Avatar
Coach32
some one should invent an air bag system to go under the middle section of the car to lift it.
Old Nov 26, 2013 | 10:23 AM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
Do a search here, there are several threads that discuss how to lift up the front or back, both sides at the same time using either a manufactured arm, or a wooded self made arm that will left up both sides at once.
No way would I try to do one point at a time.
Old Nov 26, 2013 | 10:40 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Been there, done that. True it looks scary. Once it was up and a few beers down, we shook the car pretty hard only to decide it is stable.
Now if you really really want something scary, jack up the back so the bottom of the the bumper is 29" off the ground, high enough to swap out the cat back exhaust.
The clutch scared the neighbors, the cat back scared me.
Old Nov 26, 2013 | 10:42 AM
Pfadt Racing's Avatar
Pfadt Racing
I bought two low profile jacks or this reason...
Old Nov 26, 2013 | 11:23 AM
hmmmm16417's Avatar
hmmmm16417
I lifed the rear w low profile jack and placed on jack stands. That allowed me to reach the front frame w low profile jack. However, rear stands started tipping as the front lifted so I had to lift rear w another jack to reset the stands. Went back n forth till front was high enough for stands.
Old Nov 26, 2013 | 02:00 PM
Cardinal Flyer's Avatar
Cardinal Flyer
I think it was less than $10 to build the wooden support!
Old Nov 27, 2013 | 01:32 AM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
Has anyone used these? Not cheap but seems better than wobbly jack stands.
http://www.jackpointjackstands.com/Home.html
Old Nov 27, 2013 | 01:49 AM
MawneeC5's Avatar
MawneeC5
Piece of cake I've done over half a dozen clutch jobs on jackstands now.
Old Nov 27, 2013 | 02:35 AM
laurent_zo6
You're a braver man than me. I will not rely on the strength of a jack stand pin to support over a 1,000 lbs.
To putting vette on jack stands
Old Nov 27, 2013 | 02:55 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
If you dont have 6 tons jack stands or a lift it is.
Old Nov 27, 2013 | 05:56 PM
GoldenFlame's Avatar
GoldenFlame
Ha, I did too! Not bad, just time consuming.
Old Nov 27, 2013 | 07:28 PM
Ona mission's Avatar
Ona mission
St. Jude Donor '14
Do you want to swing by and help me swap out my clutch before Christmas?
