Started my major upgrades!
Rick is meticulous and does excellent work and keeps customers fully informed along the way, plus he's one of the nicest people you'll meet.
He did the installation of my TR6060 trans w/C6Z06 differential conversion.
I would recommend him to anyone, without hesitation.
Last month I relocated the coil packs...
15 minutes to remove it....NOT! Was going to mount the brackets to the frame until I got on the passenger side and saw the PCM was mounted on that frame. So much for that idea. Back to the original plan... Decided to go with LS7 coils for the relocation.
With the hard part done I made sure for the unlikely event of any maintenance type issues (i.e. bad wire or coil) I only had to remove the back wheel well shroud and the bolts from the bottom of the fender near the door for access. The wires are Davis Unified Ignition 10mm with heat shielding.
I did end up changing the #4 wire from 45* at the plug to straight.
This month I got a steering wheel from Northern Corvette and a new Nappa leather cover from Redline Goods with the actual covering being done by one of their preferred upholsterers, Nora Gonzales. The new wheel is very soft and easy to grip.
Last weekend I installed my new valve covers.
I'll be working on my billet fuel rails today...hopefully.
I started with the fuel line and once I got the female 3/8 to female -8AN connector and line on I moved on to the rails.
Turned out the fuel line was too long so I had to put a few "curves" in the line.
This cause the feeder connector to be pointed towards the brake booster instead of remaining straight. Additionally, I was checking out the setup Rick (RKT Performance) was using on his 440 build. He really like the rails I had and gave me his
I was able to make a 90* connection at the fuel feeder...
and shorten the fuel line to run it parallel to the valve cover...
Once I had the lengths I was happy with I tightened them down to the angles I wanted and added heat shielding to insulate the fuel line from rattling against the brake booster or the valve cover...
This video was during the 3rd heat cycle. During the first heat cycle I discovered where I had not tightened the connections enough. No leaks observed during the 2nd or 3rd heat cycle.
I put the heat shielding on after I confirmed I had no leaks and fired it up again for a final confirmation. Looking forward to showing this off at my Sunday meetup group
Rick is such a great mechanic. Met Rick this summer when I took my Z06 to his shop. The first thing that you notice is how clean the shop is. When you email him, he gets back to you right away. He will tell you exactly what you need and will not make you pay for unnecessary work.He can do it all from the simplest procedure to the most complex. I trust him completely.
