[Z06] bad gasoline
Old Dec 3, 2013 | 05:36 PM
jonas winslo's Avatar
jonas winslo
Cruising
Default bad gasoline
I drove my 2002 Z06 home Friday after a hot and hard day at the track with it running just fine, even after a new tank of Shell I got about 20 miles before I parked it for the weekend.
Sunday it tried to start with a small back fire or two. Put some heat in and replaced the fuel filter and it’s the same, tries to start but just for a second every now and then. No water in the oil or oil in the radiator, plugs are dark but seem OK.
I stopped by the dealership and they have a left and right fuel pump for about $800 for the left or what they called primary and with my good old boy discount, which everyone gets, it’s still 6 something.
Should I drain the tank?
Old Dec 3, 2013 | 11:20 PM
spdislife's Avatar
spdislife
Curious as to how you've concluded it's a fuel, or fuel delivery problem.
Old Dec 4, 2013 | 12:20 AM
punz's Avatar
punz
St. Jude Donor '12-'13-'14-'15
Mine barely wanted to run when I had a broken valve spring. Changed wires, plugs, still bad. Was thinking fuel or fuel delivery when I pulled passenger valve cover, very easy and quick, bingo had a winner. Pull your codes, p0300 - engine misfire detected? Fuel pump and return line check valve should be able to be checked at fuel rail with fuel pressure gauge, correct? Good luck hope its something minor.
Old Dec 6, 2013 | 12:59 AM
rustyguns's Avatar
rustyguns
RUN THE CODES! COULD BE JUST A BAD WIRE!
Old Dec 6, 2013 | 08:01 PM
Xx_Black-out's Avatar
Xx_Black-out
St. Jude Donor '08-'11-'12
My old '02 Z06 has similar problems as described above. It also turned out to be a broken valve spring...
Run the codes and do some research before throwing down the money
Old Dec 6, 2013 | 11:20 PM
Cucho03's Avatar
Cucho03
I do not know the code, but I had similar issues with my C5Z and turned to be the crank sensor.
To bad gasoline
