driving ur c5 in winter
Old Dec 4, 2013 | 12:59 PM
Kreeess's Avatar
Kreeess
Default driving ur c5 in winter
want to see how many people drive their Corvettes in the winter and how long they warm it up for before actually driving.. my car is NOT garaged parked I live in CA although it may not snow but temps can get pretty low where i live... today was 36 degrees this am so my question is on a slightly modded car how long should warm up be before taking off.. i usually dont gun in anyway till i get oil temps of at least 160.. but just out of curiousity for those who DD their cars..
Old Dec 4, 2013 | 01:07 PM
3sACROWD's Avatar
3sACROWD
You shouldn't need to treat it any different than any other car. As with any engine, you shouldn't jump on it until the engine and transmission have had time to get to operating temperature. Letting it "warm up" is just a waste of gas when driving it normally.
I drive mine until the salt hits the roads in Michigan. Some days it is in the high teens / low 20s when I head to work.
Old Dec 4, 2013 | 01:25 PM
Kreeess's Avatar
Kreeess
so even with a moderate cam, "warm up" isnt necessary as long as I drive my car like a civilized human being? I always thought it needed a while for oils to circulate and warm up especially when using 10w?
Old Dec 4, 2013 | 01:28 PM
johnson-rod's Avatar
johnson-rod
I let it warm up for 5 to 10 minutes in cold weather. It's more for me than the car. By that time the rear defroster has done it's work and the front one is coming along. I still have to double clutch it through 2nd gear the first time.
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I normally drive the vette all year long except when the snow hits the streets. I've never warmed it up. Typically I get the active handling warm up message because I live off a dirt access road and drive that slowly until I pass my gate and then it's onto the highway.
rr
Old Dec 4, 2013 | 01:29 PM
Kreeess's Avatar
Kreeess
but why ?
Old Dec 4, 2013 | 02:17 PM
3sACROWD's Avatar
3sACROWD
I'm assuming you're using a 10W - 30 or 10W - 40 oil. The 10w indicates the oil will flow and protect as a 10 weight oil down to around -4 degrees F.
This is my opinion only. I don't have a cammed engine so others may chime in. I would think you'd be sufficiently protected without warming the engine in temps 20+ and just driving it "as a normal person." I also think this is being very conservative.
Driving your car as a "normal person" will actually get your engine to operating temp faster than just idling in the driveway. As far as me personally, I don't warm up any of my vehicles if the temps are above zero. If below zero, I listen to the engine to determine if warm up is needed. If the engine is turning freely then I put it in gear and go. If it is running a bit sluggish, I'll wait.
Old Dec 4, 2013 | 02:22 PM
E-Emmons's Avatar
E-Emmons
I usually have to double clutch the first few gears in the cold.. Once the trans fluid is warms up, about 5 minutes, the resistance into gears goes away. I get no resistance with the double clutch.
Old Dec 4, 2013 | 02:26 PM
66dts-v's Avatar
66dts-v
It was 22 degrees this morning and I didn't drive mine due to ice on the pass. I plan to drive it year round minus days that are slick (I take my truck).
Old Dec 4, 2013 | 02:32 PM
mrm13's Avatar
mrm13
I just got done for the season
Old Dec 4, 2013 | 02:35 PM
Kreeess's Avatar
Kreeess
this is good info, i usually let the car hit 80deg before i pull out of the driveway and drive it very conservatively till i reach 140deg plus... i'd like to hear from the cam'd guys what their opinions are
Old Dec 4, 2013 | 04:19 PM
Lee DeRaud's Avatar
Lee DeRaud
This whole discussion rides on the definition of "cold". I look at it this way: the car's normal operating temps (oil and water) are in the 190-200F range, so 80F is "cold" from the engine's point of view. Some restraint is necessary until the engine is all the way up to full operating temperature, but why treat it differently at 35F than at 80F?
Driveway warm-up is something I do when I want the inside of the car warm enough for me before I drive off. And thankfully, that is not an issue where I live.
Old Dec 5, 2013 | 05:26 PM
Kreeess's Avatar
Kreeess
so with the way my cars set up in CA winter what do you sugges
Old Dec 5, 2013 | 05:37 PM
TXGS507's Avatar
TXGS507
umm... NO... Here is where you will find mine....
Old Dec 5, 2013 | 05:55 PM
trailerguy's Avatar
trailerguy
1st Gear
Not as corvette rich as you are for sure...but mine is kept garaged and covered except for those sunny weekend drives over to Santa Cruz. I feel one of those weekends coming up quick.
Old Dec 5, 2013 | 06:09 PM
Lee DeRaud's Avatar
Lee DeRaud
You're in the Bay Area? You don't have winter in any meaningful sense of the word.
Drive it the same way all year: you're no more likely to blow it up between September and March than you are between March and September.
Old Dec 5, 2013 | 06:12 PM
racebum's Avatar
racebum
drove mine today, 34deg on the screen outside. no problems with the clutch or shifting at all. do have redline in the trans and rear end though. that stuff flows wonderful even when it's below freezing
only thing i'm considering is putting my stock wheels back on. hate driving on the pss when it's freezing. isn't good for the rubber
To driving ur c5 in winter
Old Dec 5, 2013 | 06:48 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Drove mine this frosty morning with the temp around 23 degrees. Forgot to put something over the windows last night so let it run with the front and rear special defrosters on.....not long and could scrape some and use the wipers. No problem. Roads were cold but dry.
Old Dec 5, 2013 | 07:22 PM
dangerz's Avatar
dangerz
St. Jude Donor '09-'10
From an hour ago.
It's my daily driver. I let the oil warm up to at least 70-80 degrees before I go anywhere.
Old Dec 5, 2013 | 07:42 PM
SG Lou's Avatar
SG Lou
I drive mine on and off all winter long here in New Jersey, as long as there is no Salt, Snow or Ice on the roads !
