[Z06] 03 Z mods
Old Dec 14, 2013 | 02:20 PM
moravette's Avatar
moravette
Default 03 Z mods
I have a 03 Z, so far I've put on just the b&b bullet exhaust, a vortex ram air, and a short shifter. I'm about to add some long tube headers and X pipe. But what are some suggestions on what else I can add? I thought maybe my intake to a fast intake bigger injectors? I want to in the future put a super charger so I don't want to put a cam in.
Old Dec 14, 2013 | 06:35 PM
bikeriderga's Avatar
bikeriderga
I would just leave it to adding the long tubes, unless you plan on a Cam.
The fast 92 would help with performance some, but if you are going to Supercharge, I would consult a Corvette performance shop on the SC you plan to install and get their recommendations.
Performance components need to be matched correctly, not just pulled off a shelf. You could spend a wad of cash without any real long term benefit.
The Long Tubes will help with a SuperCharger or naturally aspirated upgrades. That is one component that is going to help performance either way and can be used as an incremental upgrade path.
Old Dec 18, 2013 | 12:45 AM
Z06TWT's Avatar
Z06TWT
I track my C5Z so I went with seats, harness bar, brakes, coilovers, sway bars, fluid coolers, etc. If you know where you want to end up (blower) then talk to a speed shop like MTI racing in ATL to make sure you are putting on compatible parts......by the way, I have seen a few of their supercharged LS engines and they are wicked.
To 03 Z mods
