Switchback LEDs
Old Dec 15, 2013 | 03:15 PM
Tim04C5's Avatar
Tim04C5
Default Switchback LEDs
I just installed these and the hyperflash relay.
With key off, I turn parking lights on, and the SB's light up white. I thought the amber would be on. Then I turned on the headlights, they came on normally and the SB's were still on, in white.
With key on, rear turn signals work normally, front SB's do nothing, either side.
Car running, the SB's were not on. Normally the DRLs are on.
I thought this was plug n play? The stock lamps were functioning normally. Any ideas?
Old Dec 15, 2013 | 03:23 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Try this, get the LED bulb, unplug it, and give it a 180° turn.
I had issues with LED before, I think they are a PITA.
Old Dec 15, 2013 | 04:11 PM
Tim04C5's Avatar
Tim04C5
I tried flipping them and they're doing the same thing. Apparently the amber part isn't working.. taking the relay out didn't do anything either...
Old Dec 15, 2013 | 04:25 PM
Phanni's Avatar
Phanni
Try turning the multi function switch to the first 'on' position and see if they work there. I think mine only flash back it the lights are on.
Old Dec 15, 2013 | 04:27 PM
Clancy209's Avatar
Clancy209
went back to stock
Old Dec 15, 2013 | 10:31 PM
mstromquist's Avatar
mstromquist
2015 C5 of the Year Winner
When I turn the key on they light up amber, DRL's. With the lights on they are white. The turn signal is amber and the white doesn't even come on until the blinker is canceled if the lights are on and goes back to amber if the lights are off. It does sound like your amber lights aren't working though. I would contact the company you bought them from and see what they say.
To Switchback LEDs
