[Z06] Valve Springs changed..
Old Dec 18, 2013 | 06:28 AM
jmc12's Avatar
jmc12
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17
Default Valve Springs changed..
Had the springs changed out, they were the yellow ones, were those the bad batch?
Also had a left side axel seal fixed along with all fluids changed, and long tubes with X pipe installed..
Old Dec 18, 2013 | 08:16 AM
Paul 75 L82's Avatar
Paul 75 L82
You must be a happy guy. Get rid of the old springs and add on some goodies.
Old Dec 19, 2013 | 07:16 PM
vetrnz06's Avatar
vetrnz06
damn son!
Old Dec 19, 2013 | 08:05 PM
CHJ In Virginia's Avatar
CHJ In Virginia
The original OEM springs were blue. The problematic factory ones would be the same color. The yellow colored springs were the replacements from the factory and would not be a problem. You p[robably have had them changed at least once in the past.
Old Dec 19, 2013 | 09:28 PM
jmc12's Avatar
jmc12
Originally Posted by vetrnz06
damn son!
Yeah man I forgot to tell you..
Old Dec 19, 2013 | 09:32 PM
jmc12's Avatar
jmc12
They were the yellow ones, I never had them changed.. I bought my Z from Vertrnz06.. Did you ever have them changed??
Old Dec 19, 2013 | 10:27 PM
z06scentair's Avatar
z06scentair
Factory springs were in a variety of colors. Blue, Yellow, Natural, Natural with orange stripe.
I've broke a yellow intake on an 02 with 48k miles, seen at least seven other LS6's with broken valve springs, all yellow.
With that being said the part number changed in mid-2003, and have seen these replacement springs in blue and yellow.
You will be fine as long as they came from a dealer.
Old Dec 20, 2013 | 04:43 AM
vetrnz06's Avatar
vetrnz06
jmc12- no i never did anything to the car.i bought it with only 2500-2800 miles on it.based on what z06scentair and CHJ in Virginia said above i bet u were good but i think your car was an early edition '03 so who knows. but you are good now for sure.want to see it and hear it soon. bkfst in january sometime. merry christmas!
Old Dec 20, 2013 | 06:17 AM
jmc12's Avatar
jmc12
It is an early 03, I kept reading about those springs and it scared the heck out of me, so I changed them out for peace of mind.. Hate to kill a good motor with only 15K.. Man you did not drive it much, I got it with I think 5K.. How's the new one?
Breakfast soon I am ready for a road trip!! Will you be at Sebring? If you make it be sure stop in.. I am not going to make it to the 24 hours, infield is sold out..
Old Dec 20, 2013 | 07:50 PM
vetrnz06's Avatar
vetrnz06
Maybe drive over for the test-'the roar".we will be there on that saturday early -jan4.finally read on the forum and elsewhere online about the corvette new driver lineups for ''14.also said they will be at the test.come up and stay here friday eve and will take both vettes over.... the new vette is fine.up to 27,000 miles.so is the pontiac.in fact leaving in the morning for 5-6 days. alla round the southeast.... merry christmas!
Old Dec 20, 2013 | 08:14 PM
sami85L98's Avatar
sami85L98
Blue greenish color came on 01 Z06, and yellow came on 02+ Z06. Yellow on's were the problem, i never came across blue/green went broke. Good thing you replaced and next mod begins......comp Cam trunion kit for your stock Rocker arms, those needle bearings in them are some times let go, i am glad i did.
Old Dec 20, 2013 | 08:23 PM
MY03C5Z's Avatar
MY03C5Z
Bought mine 2 years ago, 1 owner bone stock with 36k, changed the springs last summer. It had bare steel springs with the orange stripe. Replaced them with the blue LS2 style springs. It was a big relief to me to get the originals out, everything I've seen was that faulty springs were the main reason for LS6 failures.
Old Dec 21, 2013 | 08:33 AM
Dave02C5's Avatar
Dave02C5
wrong. the blues are current GM replacements, there are more yellows that break than any other spring out there. Never seen any blues that break.
Old Dec 21, 2013 | 02:29 PM
racebum's Avatar
racebum
this
i have an 8/01 build date 2002 car and it had the natural with orange stripe springs. also had an 01 many years back that had blue springs
the replacements i got from gm back in april of 2013 were also blue
i even tested them on a spring rate meter and they were damn near identical to the natural with orange stripe springs
Old Dec 21, 2013 | 05:02 PM
Zealot06's Avatar
Zealot06
I'm in the middle of replacing mine right now. They're yellow on my '02 with an April 2002 build date.
None of you mentioned replacing with PAC 1218's…I'm good with those, right?
Old Dec 21, 2013 | 07:06 PM
rjwz28's Avatar
rjwz28
Yes
I just skipped the whole business, I'm running a cam with Tooley .660 duals
Mine is a late 03 anyway, so I got the 04 fuel system and valve springs but without the Nurburgring-tuned shocks...
Old Dec 21, 2013 | 07:27 PM
ZeeOSix's Avatar
ZeeOSix
Originally Posted by racebum
this
Did you buy that car new?
I also have an 08/01 build date 2002 Z06 (bought new), and it has the yellow valve springs. Was GM using 2 or 3 different springs at the same time?
To Valve Springs changed..
Old Dec 21, 2013 | 07:48 PM
z06scentair
Yes they were as I recall there was several suppliers.
Old Dec 21, 2013 | 07:52 PM
z06scentair
Actually the new replacement LS2 spring can be Yellow or Blue. Don't have time to give part numbers now. The part number changed Mid 2003 and that part number later became the LS2 part number.
Old Dec 22, 2013 | 06:18 PM
Dave02C5's Avatar
Dave02C5
NEVER seen yellow.. part # 12499224 all the new LS6/LS2 springs are blue from GM. I'd be very hesitant to replace a yellow with another yellow.. if that were the case I'd go aftermarket for sure.
