Are there LED replacement bulbs for the lights along side the vanity mirrors on the visors?
If so, do you know who sells them?
Also need directions to replace them.
That's a good question, I wish I knew. I imagine it's possible. I don't think the bulbs are a simple replacement though. This may have to be for a DIYer with some soldering.
The rear view mirror has replaceable bulbs though!
Its a 2721 bulb, which is a 1.2 watt "72" base style bulb.
Basically, any 72 style bulb will fit there. 72 bulbs are common in cars for indicator lights and such. If you google "72 LED Bulb" you'll see some examples...
I am pretty sure the bulb faces "sideways" in the housing. I.e. it plugs in the top or bottom of the housing and the side of the bulb faces you when its illuminated, so a replacement LED bulb would also have to have the LEDs on the side of the bulb as opposed to being on top of it.
