C5 kill switch?
Old Dec 27, 2013 | 02:13 PM
2000BC's Avatar
2000BC
Default C5 kill switch?
Hi,
Has anybody wired in a hidden "Kill Switch" in their C5? I used to add them into pre-computer cars long ago but not sure if that is possible anymore. I'm shipping my car down to Florida and it will be in a garage at a house I'm renting. I won't be there on weekends so I thought a little extra insurance would help. If you know how please PM me a schematic. Thanks!
Old Dec 27, 2013 | 02:34 PM
2000BC's Avatar
2000BC
I just found an old thread that answered my question. I did search General & Tech but it didn't come up. Yahoo search and up it came! Anyways, wiring in a toggle switch on my M6 clutch switch. Done! I think that will be very effective and simple. Case closed!
Old Dec 27, 2013 | 05:41 PM
Paul 75 L82's Avatar
Paul 75 L82
I had a 72 Camaro show car and I wired a kill switch up under the dash.
Old Dec 27, 2013 | 06:11 PM
I guess every little bit of safety measures helps.
Old Dec 27, 2013 | 07:42 PM
LoneStarFRC's Avatar
LoneStarFRC
That's exactly the method I used several years ago. Using the clutch switch is perfect for 6-speed cars.
Old Dec 27, 2013 | 10:06 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Bout covers it!
Old Dec 28, 2013 | 08:20 AM
Vato's Avatar
Vato
When I had to bypass the VATS system and solder in resistors to give the computer the Ohm value is was looking for I also installed a small switch in line. Hides perfect right behind the ashtray. Just remember that you turned to SOB off before you freak out that your car wont start!
Vato
Old Dec 28, 2013 | 08:58 PM
dagon138's Avatar
dagon138
I used to pull my fuel-pump fuse in my 3rd gen camaro in college. That car was always getting broken into.
Old Dec 30, 2013 | 05:21 PM
C5Txfan's Avatar
C5Txfan
Couldn't you pull a couple of fuses and not have to worry about hooking up a switch? Then put them back when you're ready to move the car ... just a thought and save a few bucks and time.
Old Dec 30, 2013 | 05:34 PM
LoneStarFRC
Time? The act of having to remove/re-install a fuse each time you park your car becomes a royal PITA and that leads to eventually not doing it all, not to mention the eventual wear-and-tear on the fuse/fuse box itself.
A well hidden switch that's convenient to you, is not only cheap, it saves time and is FAR more likely to be used on a regular basis.
Old Dec 30, 2013 | 06:08 PM
C5Txfan's Avatar
C5Txfan
I meant for his storage ... not daily use - for that a switch is best of course !
Old Dec 30, 2013 | 06:37 PM
LoneStarFRC
To C5 kill switch?
