Security System Failure
Old Dec 30, 2013 | 05:40 PM
Michael1950's Avatar
Michael1950
Cruising
Default Security System Failure
I have a 2004 C5 with 18,000 miles. I am having trouble starting it on the first start. The gauges blink off and on. If I turn the key to the off position after the first start attempt it starts and runs fine. I believe my security system has a failure but it's not displaying as a failure code. Any thoughts on this would be most welcomed.
Old Dec 30, 2013 | 05:44 PM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Just curious, why are you thinking its a security issue ?
Old Dec 30, 2013 | 11:05 PM
El original's Avatar
El original
Could be any number of things, check some of the simple stuff like air filter, fuel filter and run some fuel/injector cleaner.
Old Dec 31, 2013 | 05:11 AM
Michael1950
Cruising
Originally Posted by 8VETTE7
If it is a security system failure there will be a code stored but not displayed.
Further if it is a security system failure, when you turn the key to the on position the security light on the dash will stay illuminated. (don't need to try to crank the engine just turn the key to the "ON" position)
You can pull the codes yourself with the following procedure:
http://www.c5forum.com/ayc/dtcdic.php
OR
Pull your codes and post them here including the H or C or HC that follow the 5 character code....
Thank you great info
Michael1950
Cruising
Thank you
Old Dec 31, 2013 | 11:45 AM
dadaroo's Avatar
dadaroo
My car has done the same thing 2 times. With 60K on it I plan to replace the ignition switch since they are prone to issues. The switch is not expensive and pretty easy to replace. You still retain/reuse the actual key cylinder. If you need more info on this you can Google for info or let me know if need more info/help. With your low mileage this may not be your issue though. Just something else to consider.
Old Dec 31, 2013 | 12:06 PM
jcgunn's Avatar
jcgunn
try your other key, could be the security pellet
Old Dec 31, 2013 | 05:12 PM
Michael1950
Cruising
Thank you to all that responded. What I thought was a security system failure turned out to be a loose connection to the starter. I had the injectors cleaned and checked all of the grounds. Running great again!
Old Jan 1, 2014 | 06:00 AM
El original
Right on, thanks for sharing the solution to the problem. Happy New YEAR.
Old Jan 1, 2014 | 07:02 AM
oakvillec5's Avatar
oakvillec5
That is why this site is so good....very helpful to both new and seasoned vette owners!
Happy New Year
Old Jan 1, 2014 | 10:31 AM
Michael1950
Cruising
I agree. Happy New Year
Old Jan 1, 2014 | 10:32 AM
Michael1950
Cruising
My pleasure. Happy New Year
To Security System Failure
