The other day I was driving across Florida a distance of 200 miles at the speed of 90-100 Mph, 3 weeks later I heard a noise coming out of the engine heads below the engine cover clearly . The car runs but it shakes in low and first gear, the engine symbol is coming out flashing and the air condition stop working.
It could be a number of things but I believe if the CEL is flashing that means a cylinder is misfiring. Which sounds like broken valve spring, broken rocker arm, bad lifter etc etc etc. or it could be as simple as a bad plug wire. Pull the codes and report back.
