Oil Change question?
Old Jan 14, 2014 | 10:27 PM
  #41
thisMSGgood4me's Avatar
thisMSGgood4me
Originally Posted by JR-01
It had been sitting in the car exposed for 5 months through multiple temperature and humidity changes. Is that fresh?
Exposed? I hardly think so. It's not like you're going to remove the oil fill cap and let air freely circulate into the engine. And yes, JR, I would consider the oil to still be fresh. It doesn't matter whether the oil in the crankcase is new or used, it's still going to be subject to temperature and humidity changes. Nothing you can do about that (unless you have the luxury of being able to store your vehicle in a controlled environment). But just because it's subject to those environmental changes doesn't turn fresh (or new) oil into used oil. Running the engine over time does that. So just sitting in a crankcase over the winter should have no effect on the oil come springtime.
Old Jan 14, 2014 | 10:31 PM
  #42
thisMSGgood4me
Originally Posted by Camjamsdad
Ding ding ding. We have a winner. Oil in a sealed jug can't be contaminated with moisture. In your crankcase it can. Never in my life have I heard of carbon molecules contaminating brand new oil and turning it into acid. I've opened some sludged up engines that never ever had an oil change and nothing was eaten up or corroded. And we're talking sludged up so bad you can't see the rocker arms, and the cars still ran over 100,000 miles.
I think you forget that oil and water (moisture) don't mix. And any moisture in a crankcase, whether it be filled with new or used oil, is going to burn off rather rapidly and not be an issue.
Old Jan 14, 2014 | 10:37 PM
  #43
thisMSGgood4me
Originally Posted by Kreeess
the way I look at this situation....
pretend you have a can of soda, you open the can of soda and transfer it to sealed bottle.
although you never drank out of the soda and it just went from its original seal to another... would you still want to drink the soda after a week ? No right cause more likely it will be stale... haha idk if that makes sense to anyone else but thats my whole view in this..
FWIW oil changes are not too hard to do and it doesnt cost much to do. in the end its up to you what you want to do.. just make sure to warm up oil to operating temp if its been sitting for a while
If they ever start carbonating motor oil, you might have a valid point, Kreeess, but I really don't think that's EVER going to happen, so your "view" makes absolutely no sense.
Now if you were just trying to be humorous, I think you made your point.
Old Jan 14, 2014 | 10:47 PM
  #44
Kreeess's Avatar
Kreeess
I was just tryin to lighten up the thread.., seemed like everyone needs a laugh from an idiot guy like me, I'm def no pro
Old Jan 14, 2014 | 11:14 PM
  #45
Vette_DD's Avatar
Vette_DD
The pissin matches are going to stop if every thread in this section has to get closed.
Either debate the subjects peacefully or find somewhere else to go.
Personal attacks/hostility toward others
The Forum should be a place where we treat one another with civility so that it remains a fun and friendly place to hang around with other Corvette enthusiasts. Hostility to others is rude and inappropriate.
Personal attacks cannot be tolerated. Attack ideas, not fellow Forum members.
http://forums.corvetteforum.com/foru...rd-others.html
