Help getting these decals off
Old Feb 1, 2014 | 03:04 PM
Vettecruzer's Avatar
Vettecruzer
Default Help getting these decals off
Dose anyone have a good idea of how to get this silver decal stuff off the inside of the letters? It started chipping a while ago.
Old Feb 1, 2014 | 03:06 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I would try a heat gun and just remove them, Then install what you want new.
Old Feb 1, 2014 | 03:10 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I hear a lot people use WD40, I would try goo be gone and some Q-tips or some kind of soft plastic trim tool/ tooth brush, than a cleaner wax and re-wax.
Old Feb 1, 2014 | 03:19 PM
Either of the two methods mentioned above would work. Good luck.
Old Feb 1, 2014 | 09:20 PM
Vettecruzer
Thanks for the ideas, I will give them a try. I don't think I will put anything back inside the letters.
Old Feb 1, 2014 | 09:35 PM
kabluie's Avatar
kabluie
Do not use a toothbrush on your paint. The brush will scratch your paint.
Old Feb 1, 2014 | 09:41 PM
WICKEDFRC's Avatar
WICKEDFRC
Would NOT use a heat gun as you may bubble your paint.
I DO suggest a hair dryer.
Heat the area to be peeled and it should peel off easily. Use Goo-gone to clean residual gunk. Polish, wax.
Old Feb 2, 2014 | 10:00 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Best advice you received right here. A heat gun is way too much heat.
Old Feb 2, 2014 | 10:12 AM
Mr.Bill's Avatar
Mr.Bill
I used a heat gun with a low and high setting on low and had no issues at all.
Old Feb 2, 2014 | 10:17 AM
Hauln1203's Avatar
Hauln1203
a little common sense and a heat gun work best...
Old Feb 2, 2014 | 11:31 AM
Black0ut's Avatar
Black0ut
heat gun, low settings.
3M adhesive remover. Works exceptionally well.
Old Feb 2, 2014 | 02:48 PM
Vettecruzer
3M adhesive remover might do the trick since 3M probable made them.
Thanks again for all the advise I really appreciate it.
Old Feb 2, 2014 | 03:20 PM
Witmer's Avatar
Witmer
I successfully removed the rear bumper decals with the dealership name from all of my vehicles with a clay bar and detail spray. This may not be the same as what you are trying to do, but certainly a safe thing to try.
Old Feb 2, 2014 | 05:53 PM
jrose7004's Avatar
jrose7004
Goof Off could be another option if the heat gun won't work.
Old Feb 2, 2014 | 08:41 PM
Z QQH 6's Avatar
Z QQH 6
Senior Member
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Hair dryer works best. Even gets those metal/plastic chrome letters the dealer puts on so you can advertise for him for free
Old Feb 2, 2014 | 09:55 PM
yanmar's Avatar
yanmar
3m adhesive remover works best.............
Old Feb 2, 2014 | 10:22 PM
dannyman's Avatar
dannyman
Use a heat gun or hair dryer. Heat sufficiently that the individual letter is saturated with heat. When the correct temperature is reached the glue will come off without leaving any residue.
Dannyman
To Help getting these decals off
Old Feb 2, 2014 | 10:40 PM
duramaxsky's Avatar
duramaxsky
That's how I took them off my C5 when I got it. Worked great.
Old Feb 2, 2014 | 10:51 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
sandblaster???
One more reason I won't have those silly things...
Old Feb 2, 2014 | 10:56 PM
Joe_A's Avatar
Joe_A
St Jude Donor '15
Heat gun can do a lot of damage
