'96-'97 LS1 Crate Engine...untouched
Old Feb 4, 2014 | 09:24 PM
joseph p's Avatar
joseph p
Default '96-'97 LS1 Crate Engine...untouched
I'm helping an older drag racer/hotrodder/corvette guy to sell off his collection. Amongst other things, he has a complete LS1 engine he bought in 1997, brand new in crate. He never took it out of the crate and it has remained in his temperature controlled warehouse. I have absolutely no idea what an engine like this is worth in this condition.
Could somebody tell me what is a realistic price to ask for this engine, so I could sell this stuff quickly and efficiently for him? I have checked Ebay and can't find a "brand new" LS1 to use as reference.
I will put it for sale in the C5 parts for sale section first, so a Corvette brother can have first shot at it.
Old Feb 4, 2014 | 09:42 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
To be allowed to sell parts owned by a friend you will have to obtain permission from an Administrator to do so.
Forum members are welcome to sell a Corvette or Corvette parts they purchased for their own personal use. Anything else is considered to be a commercial sale.
MEMBERS ARE ONLY ALLOWED TO LIST CARS AND PARTS THAT THEY PERSONALLY OWN.
* Listing cars and parts for family or friend will not be allowed without prior approval by an administrator.
* These vehicles listed must be titled in the member's name prior to listing here on the forum.
Old Feb 4, 2014 | 10:12 PM
joseph p's Avatar
joseph p
Sent PM to Tact....might even have sent it twice...accidentally.
Old Feb 4, 2014 | 11:42 PM
silver408z's Avatar
silver408z
Weird that it has a drive by wire throttle body and the corvette fuel rail covers.
Old Feb 4, 2014 | 11:46 PM
Patches's Avatar
Patches
Very strange - notice the throttle body. No motor - it's like the cable-operated f-body TB. It also has EGR like the f-body. This is, indeed, rare.
Old Feb 5, 2014 | 12:58 AM
momo20's Avatar
momo20
I have my doubts on that being a true drop in corvette LS1 I am thinking its more of the F-body LS1 with corvette engine covers ..which also hints is the fact the throttle body..but value I would say a lot less then what they go for new from any crate catalog you can get them from...not sure if you would have to tear it apart and put fresh gaskets or not for something that has been setting that long????
Old Feb 5, 2014 | 08:56 AM
sfc rick's Avatar
sfc rick
ditto....
Maybe $2500..... and that's asking a lot considering the risk and labor involved in tear down, inspection and replacement gaskets. Just think, it hasn't spun over in 17 years since it was put together during assembly. It probably is perfect, but you never know for sure until you turn it over.
Old Feb 6, 2014 | 11:29 AM
joseph p's Avatar
joseph p
Apparently from the responses I've gotten, this is not a Corvette but a Camaro/Firebird engine. The box has a shipping date of Oct '97, so maybe it's a '98?? Can anyone tell?
I'm not going to sell it on Corvette Forum and am embarrassed that I thought it was a Corvette engine, I will probably just put it on Ebay.
I've attached some more pics and would appreciate if anyone could tell me more accurate info about it and whether $2500 should be the price-range I should shoot for.
Thanks for your time.
Old Feb 6, 2014 | 01:07 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
Just put it on ebay with a 'feeler' auction...will give you an idea what someone is willing to pay for it...be aware shipping is a huge nick, so maybe offer local pickup only.
Old Feb 6, 2014 | 07:45 PM
screeminc5's Avatar
screeminc5
perimeter bolt valve covers (806 heads), egr provision, cable operated throttle body...yup thats an f body ls1 with vette frc's.
Old Feb 6, 2014 | 11:13 PM
zagger's Avatar
zagger
Not to mention oil pan. The issue I would have with this motor is the fact it has been sitting for such a long time. If it was in a temperature controlled environment the gaskets might not be to bad. It's the dried up lube on journals etc. that would terrify me. personally I would have to tear it down and re assemble before installing and firing it up. As is, it will probably fire right up but it may destroy itself in minutes.
Old Feb 7, 2014 | 06:53 AM
Cybermind's Avatar
Cybermind
If I were you, I would remove the Corvette fuel rail covers. It may be construed as misrepresenting the engine and you could end up with problems with potential buyers on Ebay. By the way since that engine does not have drive by wire, it may actually be more desireable for most hotrodders.
Old Feb 7, 2014 | 10:04 PM
joseph p's Avatar
joseph p
I think you're right, I will remove the covers before I put it up for sale. I thought it is drive by wire...???
Can someone help me....what is drive-by-wire anyway?
Old Feb 8, 2014 | 06:53 AM
Cybermind's Avatar
Cybermind
Here you go. Definition straight from Wikipedia:
Electronic throttle control (ETC) is an automobile technology which electronically "connects" the accelerator pedal to the throttle, replacing a mechanical linkage.[1] A typical ETC system consists of three major components: (i) an accelerator pedal module (ideally with two or more independent sensors), (ii) a throttle valve that can be opened and closed by an electric motor (sometimes referred to as an electric or electronic throttle body (ETB)), and (iii) a powertrain or engine control module (PCM or ECM).[2] The ECM is a type of electronic control unit (ECU), which is an embedded system that employs software to determine the required throttle position by calculations from data measured by other sensors, including especially the accelerator pedal position sensors, engine speed sensor, vehicle speed sensor, and cruise control switches. The electric motor is then used to open the throttle valve to the desired angle via a closed-loop control algorithm within the ECM.
The benefits of electronic throttle control are largely unnoticed by most drivers because the aim is to make the vehicle power-train characteristics seamlessly consistent irrespective of prevailing conditions, such as engine temperature, altitude, and accessory loads. Electronic throttle control is also working 'behind the scenes' to dramatically improve the ease with which the driver can execute gear changes and deal with the dramatic torque changes associated with rapid accelerations and decelerations.
Old Feb 8, 2014 | 01:26 PM
troyguitar's Avatar
troyguitar
The terms are confusing.
"Drive by wire" is used to mean an electronically controlled throttle, as opposed to the old school mechanical cable connection.
"wire" = electronic, "cable" = mechanical.
Old Feb 11, 2014 | 07:54 PM
joseph p's Avatar
joseph p
So you're saying this is not a "drive by wire"?
Old Feb 11, 2014 | 08:05 PM
Sam Handwich's Avatar
Sam Handwich
Default means something else
It can also refer to steering.
Old Feb 11, 2014 | 10:17 PM
1999corvettels1's Avatar
1999corvettels1
Correct, that is a drive by cable.
Old Feb 11, 2014 | 10:34 PM
LoneStarFRC's Avatar
LoneStarFRC
The LS1 first appeared in Corvettes in 1997.
The LS1 first appeared in F-bodies in 1998.
The Oct '97 date, plus all the other characteristics already mentioned, indicates this is indeed an F-Body (Camaro/Firebird) engine originally built for the 1998 year model, which is also the first year the LS1 appeared in Camaros/Firebird Formulas and Pontiac Trans-Ams. As someone else stated, I think someone has simply snapped the Corvette fuel rail covers on it.
HTH
To '96-'97 LS1 Crate Engine...untouched
