Reverse lights
Old Feb 9, 2014 | 05:04 PM
silverbandit's Avatar
silverbandit
Default Reverse lights
Where is the fuse or relay located on the c5 coupe
Old Feb 9, 2014 | 05:24 PM
JR-01's Avatar
JR-01
The diagram is in your owners manual. If you don't have one it can be downloaded online.
Old Feb 9, 2014 | 06:11 PM
65GGvert's Avatar
65GGvert
If you have a manual transmission, a shorted b/u switch in the transmission can blow that fuse. Disconnect the plug and replace the fuse. If it stays ok, plug the b/u switch back in, if it blows you need to replace the switch. Not expensive and not hard to replace. Automatic is a different story.
Old Feb 10, 2014 | 01:51 PM
silverbandit
My car is a standard shift so where is the reverse switch located on the trans mission?
Old Feb 10, 2014 | 03:30 PM
LoneStarFRC's Avatar
LoneStarFRC
#7 - Right side
Old Feb 10, 2014 | 04:21 PM
silverbandit
Originally Posted by LoneStarFRC
#7 - Right side
Thanks is this a common part or is it a dealer item only
Old Feb 10, 2014 | 05:18 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
should be available over the counter in any decent auto parts house like NAPA.
Old Feb 10, 2014 | 07:56 PM
LoneStarFRC
Same one used in a wide variety of GM vehicles for a number of years. Just don't over torque it.
Old Feb 10, 2014 | 08:14 PM
silverbandit
Thanks everyone for the info will be tackling this project next weekend
Old Feb 10, 2014 | 08:48 PM
Thanks for the info. BTW, where is the switch located on an automatic tranny?
Old Feb 10, 2014 | 09:23 PM
LoneStarFRC
Pretty sure it's on the gear selector assembly that mounts to the side of the trans, where the shifter cable attaches. Part of the Park/neutral switch assembly.
Edit #1
To Reverse lights
