Removing C5 seats
Old Feb 10, 2014 | 06:32 PM
TEECEE's Avatar
TEECEE
Default Removing C5 seats
has anyone removed their seats from their c5? Just got my new AWESOME seat covers and just wondering if taking the seats out is easy!! Love to here any feedback. Thanks!
Old Feb 10, 2014 | 06:37 PM
sfc rick's Avatar
sfc rick
Piece of cake! They almost remove themselves.
Old Feb 10, 2014 | 06:53 PM
TEECEE's Avatar
TEECEE
Nice! even I should be able to get them out! HA!! Thanks!
Old Feb 10, 2014 | 07:27 PM
PhysicsDude55's Avatar
PhysicsDude55
4 nuts, 2 plugs on driver side. 4 nuts, 1 plug on passenger side. Really easy. I believe they are 17mm nuts? Can't remember. 15, 17, or 19, one of those.
Old Feb 10, 2014 | 07:45 PM
DanSavage's Avatar
DanSavage
15mm nuts. (I just did mine --added seat heaters)
If you're pulling them by yourself, just make sure you ate your Wheaties, because they are a little on the heavy side.
Convertibles would be the easiest because you can just fold the roof out of the way. Next would be the coupes because you can remove the top. FRC and Z06 would be the most difficult because you'll need to pull the seats out of the door opening.
Old Feb 10, 2014 | 07:46 PM
TEECEE's Avatar
TEECEE
Passenger side OUT! Simple! and yes, they were 17mm nuts!!!
Old Feb 10, 2014 | 10:07 PM
Very easy but a word of caution - be sure to place a blanket or thick towel down over the sill plates to prevent any possibility of scratching them.
Old Feb 11, 2014 | 11:18 AM
dadaroo's Avatar
dadaroo
If you are replacing the actual seat cover material, this video is really good and may help. Not directed at actual cover replacement but it is at least some good info.
This may help too on seat cover replacement, not my info but:
See my post (#6) to this link. It gives you links to a couple of others' rebuilds of their seats. Some good ideas for you to consider.
http://forums.corvetteforum.com/c5-t...post1585741267
Old Feb 11, 2014 | 11:48 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Think about heading off "rocking seat" if your driver's seat isn't already rocking. Good luck!
Old Feb 11, 2014 | 01:51 PM
dimler's Avatar
dimler
Default Insulation ?
If your that far into it, maybe, just maybe adding some insulation to the tunnel, floor board area and BEHIND the seat. Reducing noise and heat can be a beautiful thing.
Old Feb 13, 2014 | 07:24 AM
TEECEE's Avatar
TEECEE
Thank you all. That video should be helpful. Seats came out with ease! But changing the covers looks much harder then expected. Guess i will give it a try!!
Old Feb 13, 2014 | 08:02 AM
memmer's Avatar
memmer
A word of caution, when you go to remove the plastic corners where the seat controls are be careful as they are easy to break.
Fred
Old Feb 13, 2014 | 11:29 AM
TEECEE's Avatar
TEECEE
Old Feb 13, 2014 | 02:15 PM
DanSavage's Avatar
DanSavage
I just replaced the driver's side seat back halo and seat foam. Once you dive it, it's a lot easier than it looks from the tutorials.
I would suggest you buy yourself a set of hog ring pliers, some hog rings and a big pair of side-cutters to cut the old hog rings off. Having these tools makes the job much easier.
I would also suggest you perform Junkman's seat reinforcement to stave off future wear on the foam.
http://www.digitalcorvettes.com/foru...d.php?t=104955
While I had the seats out, I also installed Rostra seat heater kits.
To Removing C5 seats
