Still no start
Old Feb 13, 2014 | 05:57 PM
metalheadbusa's Avatar
metalheadbusa
Default Still no start
Hey guys . I know I have bugged this forum till death. But I have another question. Before I shell out a ton of money for a BCM is there anywhere else I need to check why my car will not start. I had a diode put in my BCM but it didn't work still won't start. My car is 99 c5 . The BCM got wet, I thought I had all of the coolant clean up but nope it went to smoke and my car hasn't ran since.
Old Feb 13, 2014 | 06:16 PM
Phanni's Avatar
Phanni
If your BCM got wet, it's likely toast.
I suggest you contact one of the Corvette recyclers here on the forum and they can most likely help you out. The BCM will need to be programmed to you specific car, but that's not a big problem for someone with the right equipment.
Old Feb 13, 2014 | 10:35 PM
metalheadbusa
Originally Posted by 8VETTE7
Have you been able to pull codes????? What are they?
I haven't been able to get any . I didn't think I should hook up my scanner without the BCM being put back in
To Still no start
