noise?
Old Feb 14, 2014 | 11:17 AM
vrodvette's Avatar
vrodvette
6th Gear
Default noise?
recently bought a 98 c5. took a ride and it was pretty noisy, thought it was just the worn tires. bought the car, replaced the tires and it is still pretty noisy. is this typical for this car? the exhaust is loud but quiets when not accelerating, the tire noise does go away when cornering and returns to the steady hum again, worst at about 70. still love the car just wish i could hear the radio.
Old Feb 14, 2014 | 11:25 AM
rjwz28's Avatar
rjwz28
I drive a modded Z06 and I can hear the radio just fine
Have you checked the wheel bearings?
Old Feb 14, 2014 | 11:58 AM
Anchorwatch's Avatar
Anchorwatch
5th Gear
Default Noise
I dumped the good years and put on michelins. It helped but the vette is just naturally has a lot of road noise. You will get used to it after while.
Old Feb 14, 2014 | 12:17 PM
El original's Avatar
El original
Do you have a aftermarket shifter? Reason I ask if the shifter was monkeyed with the noise dampening mat on the shifter box may not have been reinstalled. A surprising amount of noise can come from there if the mat is not installed.
Old Feb 14, 2014 | 12:39 PM
RedZMonte's Avatar
RedZMonte
What tires did you install? Did you get a alignment with the new tires? that could be some of your noise.. might be wheel bearing if its a hum. Does it sound like its from the front or rear? does it change with speed or when turning?
S
Old Feb 14, 2014 | 12:41 PM
Anchorwatch
5th Gear
Default Noise
It's an auto with 10'000 mi and totally stock. If you only drive the vette you will get used to the noise, but I drive a avalanche ltr and the difference in noise is huge. Oh I do drive my vette I got this one from some Dr's estate with 7'300 mi on her about 3 months ago. Re placed all fluids and tires.
Old Feb 14, 2014 | 12:50 PM
Cybermind's Avatar
Cybermind
That's the sound of performance. It's as simple as that. You need to remember that the C5 was designed to be as light as possible and because of this, sound deadening was not a huge priority. If you think the C5's are loud, you should try a Lotus Elise. It's the nature of the beast when it comes to performance cars made primarily of fiberglass or plastic. I like the fact that it's noisy. It gives it that racecar feel.
PS: Did you know that your floorboards are made of balsa wood sandwiched between two sheets of aluminum?
Old Feb 14, 2014 | 12:52 PM
rjwz28's Avatar
rjwz28
I don't know
The Z06 has the least sound deadening and the thinnest glass, and I have absolutely no trouble hearing the radio despite the cam and headers
Old Feb 14, 2014 | 04:09 PM
Oklahoma Adam's Avatar
Oklahoma Adam
Had the same problem when I bought my 2004.
Old Feb 14, 2014 | 05:03 PM
flze01's Avatar
flze01
Cruising
If the noise changes while turning, sounds like wheel bearings.
Old Feb 14, 2014 | 06:23 PM
vpshockwave's Avatar
vpshockwave
I don't know
No problems hearing mine through cam/headers either.
Old Feb 14, 2014 | 06:42 PM
RedZMonte's Avatar
RedZMonte
Might also consider a Trunk Partition.. if you are hearing Road noise then that will make a big difference. My Z06 has one behind the seat and blocks the sound in the trunk area, makes a big difference.
S
Old Feb 15, 2014 | 01:04 AM
Could be any number of problems. Best bet is to just have the car checked over by a trusted mechanic that knows Corvettes. Good luck.
Old Feb 15, 2014 | 02:35 AM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
Now, that's sound advice.
Old Feb 15, 2014 | 09:16 AM
memmer's Avatar
memmer
I noticed that the OP didn't say what kind of new tires he had installed. Could be part of the problem.
Fred
Old Feb 15, 2014 | 11:45 AM
yaknow's Avatar
yaknow
Fred
Old Feb 15, 2014 | 12:45 PM
Cybermind's Avatar
Cybermind
Fred
Did you install Runflats or conventional? Runflats naturally make a racket, even when new.
To noise?
Old Mar 3, 2014 | 07:02 PM
vrodvette's Avatar
vrodvette
6th Gear
just changed the LH rear wheel bearing. its a new car again!!! thank you all for your help, great website. saved a ton of money getting the bearing on e-bay and having a mechanic other than the dealer install it.
Old Mar 3, 2014 | 07:20 PM
dss's Avatar
dss
Default Window noise
Mine has window noise, I think its the moulding around the window and doors let air in which causes wind noise. I have a 99 coupe.
Old Mar 5, 2014 | 02:54 AM
rjwz28's Avatar
rjwz28
Happy to help!
