[Z06] head information needed
Old Feb 19, 2014 | 08:52 PM
bada's Avatar
bada
Default head information needed
I have a 2004 C5 ZO6. From want I have read, on the forum here. This motor has a 243 head. Correct? Plus I have seen a 799 head mentioned. What is the 799? Is it better or the same as the 243 head? And what motors do the heads come on? plus I saw somewhere, that the LS2 heads are also a 243. So is the LS6 ZO6 head, the same as the LS2 head? Or is it just. A certain year head that is the same, as the LS6 ZO6 HEAD? I was thinking about buying, a set of spare heads, just to have them worked. Then collecting, a cam & a few other motor parts. Before taking the motor apart. I have a set of LS7 heads. Will they fit on the LS6 motor?
Old Feb 19, 2014 | 10:11 PM
Ferg03 Z06's Avatar
Ferg03 Z06
243 are the heads the come stock on a c5 z06..799 are the heads I believe(not sure) come on a LS1 corvette or a camaro/trans am. Most GM heads will fit on the c5z's.
Old Feb 19, 2014 | 10:17 PM
JChastain's Avatar
JChastain
Ls3 nor ls7 heads will fit the 5.7.
Old Feb 19, 2014 | 10:23 PM
Ferg03 Z06's Avatar
Ferg03 Z06
I apologize i was wrong. 799 and 243 heads are the same with the exception of the valve stems(only difference). The weight of the valve is difference. I know LS3 and LS7 heads wont fit..but 5.3 heads will and raise compression.
Old Feb 20, 2014 | 07:32 AM
bada's Avatar
bada
Thanks for the help.
To head information needed
