Two questions, ARP Studs and Hyperflashing?
Old Feb 23, 2014 | 02:01 PM
giovanni432's Avatar
giovanni432
Default Two questions, ARP Studs and Hyperflashing?
I'm about to install 19x12 on the rear with 5/8 spacers. I did this on my 98 and I had to install longer studs. The problem is I do not remember what length of arp studs I used, can anyone help? I believe they offer 1.5" and 2" ones.
Next question is I have LED strips as my front turn signals. The stock turn signal harness has (correct me if I'm wrong) a positive, negative and neutral. The LED ones I have only had a positive and negative. This is causing them to hyperflash since the "neutral" is not being used. Anyone know of a solution I could use to fix this problem?
Btw- Anyone wanting to see the centennial rims on a widebody z06, Ill be installing everything during spring break so I should have some pictures for you guys soon!
Old Feb 23, 2014 | 05:20 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I have no suggestion on the wheel studs but, you could try this to fix the hyperflash issues.
http://shop.radioflyerinnovations.co...arness-027.htm
Old Feb 23, 2014 | 07:55 PM
PhysicsDude55's Avatar
PhysicsDude55
The hyperflashing comes from the LEDs drawing less current than an incandescent bulb.
There is no "neutral" wire. The 3 wires from the stock lights are for the dual filament bulb. 1 ground wire, 1 "turn signal" wire, and 1 "running light" wire.
Old Feb 23, 2014 | 08:59 PM
I would think the hyperflash harness mentioned above would cure the rapid flashing issue. I installed one on mine due to hyperflashing from my LED taillights and it worked great.
Old Feb 24, 2014 | 07:36 AM
sunchaser73's Avatar
sunchaser73
A few links regarding ARP wheel studs:
http://arp-bolts.com/kits/product.php?PL=55
http://www.summitracing.com/search/p...rp-wheel-studs
For the Hyperflash, either a radioflyer harness or
http://shop.jwmotoring.com/C5-LED-Hy...ashHarness.htm
Or
http://www.parts123.com/parts123/yb....5Z50000050C~~~
Old Feb 24, 2014 | 04:11 PM
giovanni432
Never mind! Just realized the harness goes in the dash! Thanks guys ill try this out and see if it helps.
When I installed the LED turn signals, I had to cut off the connectors and wire them wire to wire. So would I have to buy all new connectors and then buy the hyperflash harness?
To Two questions, ARP Studs and Hyperflashing?
