Trans fluid leak!!!
Old Feb 25, 2014 | 12:26 PM
Johnljr's Avatar
Johnljr
Default Trans fluid leak!!!
Hi i have been trying to find a leak that has been going on for the past month, after driving my vette and parking in the garage i find oil which looks and smells like tranny fluid but its located more toward the passenger side front of the car.
Anybody have any clue
i tryed looking for the leak but cant find it. only some oil on the hose thats connected to the waterpump but no oil anywere else.
thank you
Old Feb 25, 2014 | 12:39 PM
Cybermind's Avatar
Cybermind
It's definitely not tranny fluid. It could be power steering fluid which is very similar in appearance to tranny fluid. Are you sure that it's not coolant. That too is redish in color but it has a very distinct smell to it. I'm assuming that you would be able to easily tell the difference. Soooo, my vote is power steering fluid leak.
Old Feb 25, 2014 | 12:55 PM
Johnljr's Avatar
Johnljr
it doesnt smell like steer fluid, and at first i thought it was coolant, i just cant find were its coming from. Could it be the cooler for the tranny fluid? is it located around that area?
Old Feb 25, 2014 | 01:06 PM
Dcollins3208's Avatar
Dcollins3208
Do you have an auto trans? The trans cooler lines are on the passengers side of the radiator, one line up top and one line on the bottom. Check those out.
Old Feb 25, 2014 | 02:35 PM
Johnljr's Avatar
Johnljr
yes it is an auto trans, i figured it was coming from the lines, i just didnt know were it is located thanks do i need to take anything off to get to the lines?
Old Feb 25, 2014 | 02:52 PM
Cybermind's Avatar
Cybermind
Oops. I assumed you were referring to a manual tranny.
Old Feb 25, 2014 | 02:58 PM
Dcollins3208
Nope, just pop the hood, stand on passengers side of car, and check lines going into back of radiator. Feel around them for a leak. May also jack car up and check the lines all the way back to the trans. They run down the passengers side of the car down around the oil pan, along the torque tube area to the trans
Old Feb 25, 2014 | 03:15 PM
Johnljr's Avatar
Johnljr
ok ill try that when i get home. thank you @ cybermind thanks too i should of been more specific
Old Feb 25, 2014 | 09:24 PM
Johnljr's Avatar
Johnljr
well i cleaned the oil off then started the car and kept checking for any leaks as the car warmed up, then once the trans temp reached about 160 the leak started slowly, but i couldn't see from the angle under the car or on the top it was leaking onto the top of the hose that connects to the thermostat but couldn't see were it was coming from FML
Old Feb 26, 2014 | 02:56 PM
Johnljr's Avatar
Johnljr
so i found the leak it was the heater hose that was attached to the res tank. 5.00 hose and clamps. so its a relief. thanks for all the help
Old Feb 27, 2014 | 05:48 AM
hoosiervette's Avatar
hoosiervette
St. Jude Donor '14-'15-'16
Good job.
To Trans fluid leak!!!
