4l60e build
Old Mar 5, 2014 | 07:25 PM
Bent98c5's Avatar
Bent98c5
Default 4l60e build
My rear seal decided to shoot fluid out all over my garage the other day and I want to pull it and build it while I replace the seal
I'm running 12# boost with a cam so figure I need it. However it has never slipped. And it's been boosted for awhile now. Like about a year and now this New York cold finally gets to it.
Can anyone recommend what needs to be done to beef it up?
Old Mar 6, 2014 | 09:49 AM
1BADAZ50TH's Avatar
1BADAZ50TH
Some common failures with this transmission include stripped reverse reaction sun shells - there is a more robust shell available. The forward sprag is also a common failure, I would replace. I believe there is also a heavier duty input clutch housing available. I am sure there are other upgrades as well. I would contact a couple of local transmission shops and see how they beef them up for additional input.
Good luck!
