automatic trans
Mar 9, 2014 | 10:14 AM
3rd Gear
automatic trans
I just bought a 93 corvette automatic with an LS1 engine in it. what gear should I be using when just cruising around town?
Mar 9, 2014 | 10:19 AM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Mar 9, 2014 | 10:52 AM
Trick question?
I'd go with "D". But if you really need more excitement in your life, try "R".
Mar 9, 2014 | 11:01 AM
3rd Gear
not a trick question
Quote:
Originally Posted by
Lee DeRaud
Trick question?
the gears are p r n d 3 2 1 the guy I bought if from said d is the overdrive for highway use only so what gear should I use when just cruising
Mar 9, 2014 | 11:03 AM
Mar 9, 2014 | 11:17 AM
I stay in 3 unless I'm on the hwy. 4th gear is the weakest of all so this puts less stress on it.
Mar 9, 2014 | 11:32 AM
C5Natie
Ah. That explains the many pages of threads about broken transmissions I've been seeing. Oh wait...
"Weakest" is a relative term. There are things you can do to bugger up that transmission, but cruising around town in Drive isn't one of them.
Mar 9, 2014 | 11:56 AM
Lee DeRaud
Trick question?
Mar 9, 2014 | 12:13 PM
Mar 9, 2014 | 12:21 PM
jrose7004
I'd use "D"!
Doh
Mar 9, 2014 | 12:25 PM
Is this a serious question???
Mar 9, 2014 | 01:01 PM
Driving around in 3rd? Just put the damn thing in drive. Its an automatic. My old trans am has a drive and and over drive. That might make sense in that car. But not a C5.
Mar 9, 2014 | 07:23 PM
Lee DeRaud
My trans is built and has handled 450 to 600rwhp flawlessly for 6yrs. I prefer 3rd for better throttle response since the rpm's will be higher and also its easier on the trans because if you floor it it doesn't have to do the 4-2 downshift. Just some of the things that I feel make it last. I'd put my 4L65E up against any other out there anywhere.
Mar 9, 2014 | 09:44 PM
Surly this is a trick question!! Keep it in "D" all the time unless you are in "P" or "R"!
Mar 10, 2014 | 04:15 AM
How many times are you going to ask this? LS1?
