Horn???
Old Mar 12, 2014 | 09:45 AM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
Default Horn???
My horn has stopped, can I just buy any cheap Autozone generic horn and wire it up and hope it works, or does it need a certain current or ohms or something like such? I just want to pass inspection?
Old Mar 12, 2014 | 11:53 AM
dadaroo's Avatar
dadaroo
The C5 has 2 horns in parallel so you would have to have 2 bad horns.
Can you use the FOB and activate the horns?
Here is the schematic. Have you verified the fuse (11) and relay (36) are good? Most of the times it is the membrane switch in the steering wheel. If you can activate the horn with the FOB, it is most likely the membrane. If you need more help we're always here.
Old Mar 12, 2014 | 12:04 PM
Good info to have. Thanks for posting the schematic.
Old Mar 12, 2014 | 12:54 PM
mojo1's Avatar
mojo1
Horn will not blow with alarm or panic, I dirrect hit it will 12V and nothing,
Old Mar 13, 2014 | 07:11 AM
dadaroo's Avatar
dadaroo
Verify the ground is good. The ground is G102 on the right front frame rail ahead of the fuse box.
May want to first check with an ohm meter from the horn to the negative side of the battery.
To Horn???
