I have an '03 z06 with eibach lowering bolts installed. The car sits nice and low, but it bottoms out and rides very bumpy on any roads that aren't smooth. Will coilovers help with these issues?
Mine feel great ,pfadt feather lights :but Pfadt has folded their tent
I bought them last year , I am slammed and never bottom out.
If you want comfy, no. It will be worse. The more you increase spring pressure, the more harsh the ride. I use lg g2 coils and the car performs like an animal, but also is rough.
From what I've heard, been told, and experienced - yes you can improve ride quality, or you can tighten it up. Assuming you are looking into adjustable ones, the range of adjust-ability is stiff -> to comfort. After that it's all up to your butt
Pfadt featherlights here. Yes, the ride quality is much smoother and nicer than stock on soft settings. Much rougher on hard settings too. Ride height adjustment too. Coilovers are great.
I agree. Even with the featherlights, I've tried all the settings and while the car no question handles better. I can only fill my scotch half way
My friend you need to start over reset them back 40 and 30 and dial them back down to 15 front and 10 back perfect setting stiff enough with smooth ride.
I've seen countless coilover threads and I'm really curious when someone is going to cough up the money for drop spindles. I have yet to see a single C5 owner get drop spindles (probably the cost verse CO's), a few C6 guys so maybe I missed the thread. IMO drop spindles would be perfect, as I like how my Z rides now but wish it was lower. I don't need "tighter" suspension or something for the track....though the DS are aimed toward the track guys, but I don't have to worry about dialing in the right height + stiff/soft settings.
Same feel, much lower stance and if you're lowered at all using the bolts, dang, you'd be set.
Coilovers are a bit too much money after looking into them. I was told bilstein sport shocks would improve ride quality on a lowered car and they're more affordable. True?
Look at STANCE coil overs, they retail for $1395 and I know you can get them cheaper, PM me for more info.
