horn issues
Old Mar 13, 2014 | 11:12 AM
mayj82's Avatar
mayj82
Default horn issues
Hello,
The other day I was driving and had a car pull out in front of me. I smashed on the horn quite hard in my frustration. When I let off of the horn it just kept on blowing. I pushed again and it quit but when I let off again it would blow again. I had to pull to the side of the road and remove the horn fuse to get it to quit. I know the issue is in the steering wheel but is there a way to get to it without the airbag blowing up in my face. Just asking for suggestions but this may have to be a repair for the pros. I would like to do it myself as it is a simple thing as to readjust the connectors but again airbag to the face is something I would rather not have happen. Plus those things are expensive. Thanks.
Old Mar 13, 2014 | 11:33 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I believe you will have to remove the airbag assembly;
http://tech.corvettecentral.com/2012...rn-switch-fix/
Good luck.
Old Mar 13, 2014 | 12:17 PM
mayj82's Avatar
mayj82
Good luck.
Thanks,
That was very helpful. Ill give it a shot here in a few days. I can live without a horn for a few more.
Old Mar 13, 2014 | 07:07 PM
Mr31FlavorsVette's Avatar
Mr31FlavorsVette
St. Jude Donor '12
I attempted to remove the air bag assembly from the steering wheel, but unless you have a quality 1 1/2" Torx bit, you risk the chance of stripping the screw. I ended up taking it to my mechanic who had it out in 10 mins I provided the new membrane that I had ordered from a CF vendor, I forget the amount, and he installed it. Labor was $60.00, well worth price vs the fear of the air bag blowing up in my face.
To horn issues
