Finally got em on. I have had em for about 3 weeks. Pulled the rear calipers and replaced with a new set I got from the previous owner. the fronts are Wilwood SL-6s. They were black anodized. Painted them too. I guess I will see how that holds up. Cleaned up in wheel wells. Touched up the rotors with BBQ grill paint I had laying around. 19x11.5 with a 3" lip in the rear with 305/30s Bridgestone RE-11s. Fronts are 18x9.5 with 275/35s. They are just right at the edge. Fronts, eh not so. Not sure what is going on. They hang out a tad. The car was set up by the previous owner with a mild track alignment. Might be shimmed out some. I know some guys were going to 265s. These would still have been out a little. I will try one on the CE vert and see if it is the same on it.
Finally got em on. I have had em for about 3 weeks. Pulled the rear calipers and replaced with a new set I got from the previous owner. the fronts are Wilwood SL-6s. They were black anodized. Painted them too. I guess I will see how that holds up. Cleaned up in wheel wells. Touched up the rotors with BBQ grill paint I had laying around. 19x11.5 with a 3" lip in the rear with 305/30s Bridgestone RE-11s. Fronts are 18x9.5 with 275/35s. They are just right at the edge. Fronts, eh not so. Not sure what is going on. They hang out a tad. The car was set up by the previous owner with a mild track alignment. Might be shimmed out some. I know some guys were going to 265s. These would still have been out a little. I will try one on the CE vert and see if it is the same on it. Attachment 47776286
So are these the stock Wilwood SL6's or some sort of custom setup like LG offers?
I only ask because I know someone around wanted to know if they fit with CCW 500's.
Weather was crummy Sunday in OKC so I didn't get much driving in. Had PS2s on previously. Some guys had said these might be noisier. Don't think that will be the case.
It is a LG setup. Uses the stock size front rotor.
