[Z06] TurnKey Engine Supply - Oceanside
Old Mar 21, 2014 | 11:10 AM
Drewster67's Avatar
Drewster67
Default TurnKey Engine Supply - Oceanside
Im looking at the LS6 long block -
http://www.turnkeyenginesupply.com/l...lock-assembly/
Does anyone have any experience with this vendor/engine supplier?
Thanks in advance!
Drew
Old Mar 21, 2014 | 09:04 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I haven't purchased from them but I would want a bit more information about the engine, build process, cam specs, head #, and warranty. I'd expect a bit more compression ratio if they were building these up from scratch. Most NA builders are shooting for 11.1 to 11.5.
I did research BluePrint engines a while back and decided to go with a different vendor and on customer reviews.
Old Mar 21, 2014 | 10:44 PM
Drewster67's Avatar
Drewster67
Thanks for the reply - I called and spoke to Kolby today and he assured me that he can do the LS6 LB but will need a week or so to build it - no core charge - 150.00 for shipping - no sales tax being I'm out of state. Engine is 100% to spec using 100% new parts and should require no flash on the ECU - direct replacement.
I also found a nice write up on his shop and turnkey engine supply was featured on a network Off Road - show. 10yrs in the business
What I did forget was to ask about the warranty -
Old Mar 22, 2014 | 08:23 AM
Z06ufgrad2002
When you do call them back about the warranty info also inquire about the brand names for the parts they are installing for the bearings, crank, rods etc. Also, if it doesn't come with the engine, be sure to run a high quality break in oil for ~400 miles.
Old Mar 24, 2014 | 10:01 AM
Drewster67's Avatar
Drewster67
Sounds good and thank you for the direction! Much appreciated
To TurnKey Engine Supply - Oceanside
