Driver door window switch panal
Old Mar 29, 2014 | 07:16 PM
silverbandit's Avatar
silverbandit
Default Driver door window switch panal
Last Sunday I broke my driver door window switches besides the mirror switch everything works and also the passenger one works I ordered another switch pannal and it's the same thing my driver window is stuck in the down position any advice would be most helpful
Old Mar 30, 2014 | 12:38 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Well if everything else works you might have a bad regulator or a bad connection on the window motor.
Old Mar 30, 2014 | 12:00 PM
dadaroo's Avatar
dadaroo
To figure out if it is the motor or the door module I would unplug the motor and jumper 12 volts to the motor. If it works and operates the window then it should be the module. If you need more info on doing this let us know.
Also, if the motor seems to work and the window does not the move regulator is probably bad. Look at it for any obvious issues.
PS: Putting voltage on the motor will cause it to rotate one way. Reverse the + and - to the motor to make it rotate the other way.
To Driver door window switch panal
