[Z06] What should I be putting down?
Old Mar 31, 2014 | 11:43 PM
DANNYZ0608's Avatar
DANNYZ0608
Default What should I be putting down?
Hey. I just bought a 2002 Zo6 and it has a few upgrades (cam. .not sure what size)..I looked at the injector they are not stock either)..head work..exhaust . And a intake. ..sorry I don't have any info and about the brands or sizes but(I'll try to get more info tomorrow) with all that done ..let's say with the smallest cam..and the next size bigger injectors then stock ...what kinda of RWHP.. Should I be putting down?
Old Apr 1, 2014 | 11:24 AM
amlarson2001's Avatar
amlarson2001
430 - 450 ish to the wheels. Depends on the cam. i make 446 with same mods.
Old Apr 1, 2014 | 12:58 PM
DANNYZ0608's Avatar
DANNYZ0608
It has a BBK intake...As far as exhaust and cams still not sure....and did you run your at the 1/4 track yet..?
Old Apr 2, 2014 | 07:11 AM
rjwz28's Avatar
rjwz28
This is silly, and total speculation. Dynos are different, operators are different, weather is different... I have a mid-range EPS cam, LSXR 102 intake manifold with a ported 90mm LS2 TB, Kooks headers and high-flow X, Halltech intake, and laid down 424rwhp at Loud Pedal Motorsports in Phoenix, AZ this past October...
Seems pretty damn low, doesn't it? However, my odds would be pretty good vs a cam-only guy who dynoed 450rwhp in Detroit in October, because there are a ton of variables between dynos AND atmospheric conditions play a large role as well
Old Apr 2, 2014 | 10:12 AM
amlarson2001
That's why i put the range in there. sorry i missed yours by 6 hp. I was just trying to give him an idea. Relax!! Im sure your car is very fun and cool.
Old Apr 2, 2014 | 01:13 PM
DANNYZ0608's Avatar
DANNYZ0608
Default What should I put down
Thanks guys but I'm taking it to a dyno end of this month and I'll let you know what it puts down and I looked at it a little better yesterday and realized that it has different headers aswell..
Old Apr 2, 2014 | 07:37 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Well as others have said.... Its hard to speculate.
You said exhaust.... what exhaust ? Long tube headers ? or just cat back exhaust ? Or both ?
Head work... are they stock 243 heads ? Some porting ?
Pics would help us all figure out what you have.
On an LS6... Just adding an intake, 1 3/4 long tube headers, cat back exhaust and a tune will give you around 390rwhp/380rwtq. A buddy of mine just dyno'd that 2 weeks ago on his new virgin 2004 Z06. I dyno'd the same 9 yrs ago on my 2004 Z06 with just those mods.
Depending on what head work you have done, and what cam size you have, will give us a better idea of HP estimates.
Some head/cam combo's can give you close to 500rwhp.
The fact that they have larger injectors on the car makes me wonder if the tuner found your car running out of fuel.
My stock injectors were running too high of a duty cycle when I was at 450rwhp/428rwtq.
I upgraded to 36lb fuel injectors to get my duty cycle down.
Maybe they upgraded because of the same reason ?
Its hard to say.
I'm at 471rwhp/441 rwtq with my setup on my LS6.
Toque
Old Apr 2, 2014 | 11:01 PM
rjwz28's Avatar
rjwz28
Sorry if I sounded snippy, it was late and we see these same questions and answers here SO FREAKING OFTEN
Hell, I'd like to know what mine would dyno under ideal conditions
Its hard to say.
Toque
Your heads are the key to your numbers; I'd love to swap these for those. Probably would net me another 25rwhp vs these PRC 5.3s.
Old Apr 3, 2014 | 10:21 AM
Toque's Avatar
Toque
I have been told that before.... I guess they just work well with my setup.
Toque
Old Apr 3, 2014 | 01:43 PM
zeevette's Avatar
zeevette
I'd suggest Trickflow 215s as done by Brian Tooley, with a matching cam. When I was NA, mine did 483/432, but I had a ported FAST90/TB and an EWP, 25% UD pulley, injectors, homemade CAI. I picked my own cam, a 228-232@112+5 and .600 lift from Crane. The setup didn't eat the stock clutch until I added the FAST.
Old Apr 3, 2014 | 07:31 PM
MotoJB's Avatar
MotoJB
...you should be putting down the blind concern for HP...at least until you know what the heck was done to your car and you actually dyno it.
So little info to go on...and any guess is therefore pretty foolish.
Old Apr 3, 2014 | 08:01 PM
rjwz28's Avatar
rjwz28
THAT was the intent of my post, it just came out more aggressive
Old Apr 3, 2014 | 08:47 PM
MotoJB's Avatar
MotoJB
Old Apr 13, 2014 | 12:48 AM
DANNYZ0608's Avatar
DANNYZ0608
Well thanks guys for all you friendly help... I'm putting it on the dyno on the 19th but I ran it today and with TC on and 19s on the back with street tires and I ran a 11.90 trap the 118mph.. and a 1.8 60ft..
Not bad ha?
Old Apr 13, 2014 | 08:17 AM
rjwz28's Avatar
rjwz28
Not bad ha?
What kind of drag strip experience?
Old Apr 13, 2014 | 12:11 PM
DANNYZ0608's Avatar
DANNYZ0608
Are you asking me how much experience I have on the drag strip?
Old Apr 13, 2014 | 11:41 PM
jake07Z06's Avatar
jake07Z06
Dyno numbers mean nothing. The quality of pump gas even comes into play. While some guys may have gotten 500whp out of their HCI setups back in 07-08, these days the same setups on the same Dyno in the same conditions would be lucky to make 480whp safely. Tuners can't advance timing like they used to because of the lesser quality of fuel. So if seller of said car quotes you a number that it put down a few years ago, don't be disappointed if it doesn't make what you expect.
To What should I be putting down?
Old Apr 14, 2014 | 07:11 AM
rjwz28's Avatar
rjwz28
Old Apr 14, 2014 | 10:10 PM
DANNYZ0608's Avatar
DANNYZ0608
To be honest I don't have to much track time and the track time I do have is with evo's , STI's.. and supras not corvettes..I'll say I been to the track maybe 5 or 6 times
Old Apr 15, 2014 | 09:06 AM
rjwz28's Avatar
rjwz28
That's a pretty solid time
Good job!
