[Z06] Supercharged Z06 dyno sheets.
Old Jul 17, 2002 | 05:51 PM
Joecooool's Avatar
Joecooool
Jax Events Coordinator
CI 3-4-5-6-7-8-9 Veteran
St. Jude Donor '03-'08
Default Supercharged Z06 dyno sheets.
In case you missed it in the C5 section, here it is again.
Some of you guys wanted to see the dyno sheet, I got it scanned in today. You can go here for more details - https://www.corvetteforum.com/lpe/index.htm
Old Jul 17, 2002 | 07:24 PM
pridnjoy's Avatar
pridnjoy
Cruise-In III Veteran
Default Re: Supercharged Z06 dyno sheets. (Joecooool)
:cool: :cool: :cool:
Old Jul 18, 2002 | 12:58 AM
EricVonHa's Avatar
EricVonHa
About 400ft/lbs rear wheel torque across 80% of the useable RPM range?? Damn, I'd say you need new tires! :lol:
Old Jul 18, 2002 | 03:16 AM
LT1pwrd'94's Avatar
LT1pwrd'94
Default Re: Supercharged Z06 dyno sheets. (EricVonHa)
Old Jul 18, 2002 | 02:20 PM
gstama's Avatar
gstama
Nice numbers on a nice car, kind of whished i stuck around to see it.
:cool:
Old Jul 18, 2002 | 03:13 PM
Joecooool's Avatar
Joecooool
Default Re: Supercharged Z06 dyno sheets. (gstama)
:cool:
How do you like your headers and shifter? Did you order the black Corvette bumper inserts yet?
Old Jul 18, 2002 | 04:52 PM
Bertrand's Avatar
Bertrand
So you should now be running the 1/4 at 11.5 @ 125 and topping out at 194 mph... Sound about right?
Oh, and my personal favorite, you should be able to hit 100 mph in 7.5 flat.
VERY NICE INDEED!!!! How does she feel seat of the pants? Do you know if LPE has any output difference if I put my 02 through the same process? Would be a rounding error at this point but I'm curious if they mentioned anything about that.
:cheers:
Old Jul 18, 2002 | 08:58 PM
RyanD's Avatar
RyanD
Default Re: Supercharged Z06 dyno sheets. (Bertrand)
If C&D got an 11.7@127 out of a coupe, shouldn't a Z06 hit 130? And it should be easily in the 10's with drag radials based on the times of other cars with similar trap speeds.
Old Jul 19, 2002 | 04:10 AM
Halltech's Avatar
Halltech
Supporting Vendor
St. Jude Donor '09
Good numbers, but you need to post the corrected numbers. They are the only numbers that can level the playing field. SAE Corrected.
Sometimes the actual numbers are important when trying to adjust fuel trims the same day when the temps or baro bump or slide the correction a percentage, when a threshold has been met in the computer, but the corrected is the only way to compare different days and is the only accepted numbers in the industry for bragging rights.
Not trying to start a flame here, since your corrected may even be higher.
Just check them out to see where it ended up.
Jim
Old Jul 20, 2002 | 05:04 PM
NoMercy's Avatar
NoMercy
Default Re: Supercharged Z06 dyno sheets. (pridnjoy)
:cheers: :cheers:
Old Jul 20, 2002 | 05:10 PM
BLU-BY-U's Avatar
BLU-BY-U
if that temp recorded on the dyno sheet is correct, then I'd say the SAE corrected # would be somewhat lower considering the 66 degree temp.
but it still looks nice and flat
Old Jul 20, 2002 | 07:02 PM
Miles in Michigan's Avatar
Miles in Michigan
Default Re: Supercharged Z06 dyno sheets. (Jim Hall)
I used this webpage: http://rshelq.home.sprynet.com/calc_cf.htm and got a correction factor of 0.975. I think it is an SAE calculator. The same guy's page had this for the SAE correction:
PS: With 459.1 and 430.1 and a CF of 0.975, you have 447.6 rwhp and 419.3 rwtq corrected.
Old Jul 21, 2002 | 07:16 PM
Z OH 6's Avatar
Z OH 6
Default Re: Supercharged Z06 dyno sheets. (Miles in Michigan)
joecooool
Great numbers. I'm only 2 weeks away from my install. Can't wait. :cheers:
Old Jul 29, 2002 | 11:01 PM
edv2122's Avatar
edv2122
Wow. I wish I had the dough to put one of those in mine! :seeya
Old Jul 30, 2002 | 12:51 AM
C5 Frank's Avatar
C5 Frank
Nice numbers.... but for some reason I was expecting more. My 94' Cobra picked up 150 rwhp with the blower and proper tuning. But I guess every car is different. Enjoy it....
Old Jul 30, 2002 | 03:44 AM
SharkbyteLT4's Avatar
SharkbyteLT4
Default Re: Supercharged Z06 dyno sheets. (C5 Frank)
:eek: wowsers :eek:
[Modified by Y2K253SS, 2:45 AM 7/30/2002]
To Supercharged Z06 dyno sheets.
