[Z06] HP/TQ #'s ????
Apr 3, 2014 | 02:45 PM
HP/TQ #'s ????
I am taking my 02 zo6 for a tune what kind #'s should I expect:
38,165 k on the clock
Vararam
Ported TB
ported and polished 243 heads
Texas speed cam .233/.239 598/608 on 112
1 7/8 kooks
Ls9 clutch
Any input appreciated.
Apr 4, 2014 | 02:21 AM
Apr 4, 2014 | 02:30 PM
Quote:
Originally Posted by
LoneStarZ06
450ish
That much HP. Doesn't that seem high for the cubes. I figured 400 to the wheels.
Apr 4, 2014 | 05:08 PM
malibu78
My 04 Z06 with only CAI/LTs/Axle-Back put down 391 to the wheels..
Your Heads/Cam (although I don't know enough about yours specifically) should put you around 440+ to the ground easy with the right tune
VPP
Apr 4, 2014 | 05:43 PM
435-445rwhp / 395-405rwtq .......depending on the compression ratio
Apr 4, 2014 | 06:12 PM
tlove32
Hell this thing should run low 11's. If i can can get a 60 ft in the 1.7's My 2012 Mustang ran 11.69 with tune slicks and front runners. It weighed 3650 with me in it and put down 399 to the wheels. This thing feels a lot faster than the stang.
Apr 4, 2014 | 07:34 PM
Similiar cam ( 232,236/ 595,601/ 113 ) but stock heads put 420 to the tires so 450 could be possible I think.
Apr 4, 2014 | 09:02 PM
jbp8653
My heads are stock to just ported and polished have you run your car down the track?
Apr 4, 2014 | 09:24 PM
[QUOTE=malibu78;1586580918]My heads are stock to just ported and polished have you run your car down the track?[/QUOTE
No. But for what its worth it has always felt just as fast as any of the bone stock C6Z's I have had. ( 06,07,09 )
Apr 5, 2014 | 07:02 AM
[QUOTE=jbp8653;1586581076]
malibu78
Wow 4 z's!!! I wanted c6 zo6 performance for under 25k that's why I went with the 02z with heads and cam. Thanks for the input.
Apr 5, 2014 | 06:06 PM
[QUOTE=malibu78;1586582912]
jbp8653
Thank You! Actually have had 27 Corvettes since 1974. 6 Z's. 2 different 02's, 3 different C6Z's, and a ZR1. Also, I remembered yesterday, I had a new 05 C6 Z51 ( traded my first C5Z in on this one ) with 4 speed. I modded it right off the bat with the same cam that I mentioned and headers. It put 415 to the tires. It ran in mid 12's on stock tires with horrible 60 foot times ( 2.25 or so ) at around 117-118 mph. Easy 11 second car with some traction. Hope this helps
Apr 18, 2014 | 09:12 PM
tlove32
Man you're good 439 hp 403 tq. Just took got it back today.
Apr 21, 2014 | 03:03 PM
malibu78
Apr 21, 2014 | 03:34 PM
tlove32
took it to the Track Saturday. Ran 11.91 @ 125.26. If it will hookup it may dip into the 10's.
