[Z06] Low oil after a week
Old 04-05-2014, 01:23 AM
Boh
Boh's Avatar
Default Low oil after a week
Got my oil changed last Wednesday. Its now Friday and i got the low oil sign.
When idling, a bit of white smoke comes out of the exhaust. Could bad valve seals burn the oil that quickly?
Old 04-05-2014, 03:42 AM
ZeeOSix
ZeeOSix's Avatar
If it's burning that much oil and there's white smoke out the exhaust pipes, then something major is wrong. Could be valve guides or rings. What's the history of the car?
Old 04-05-2014, 06:18 AM
PeteZ06
PeteZ06's Avatar
St. Jude Donor '07-'08-'09-'10-'11
Did you check the dipstick to verify its actually low?
If it truly is low...
Is there a puddle of oil under the car? Could be someone didnt tighten the drain plug or oil filter properly and you lost oil.
The bit of white smoke at idle is most likely water vapor.
Old 04-06-2014, 12:14 PM
Boh
Boh's Avatar
Dont know the history of the car apart from the fact that it has cams, intake and a tune.
The oil is actually low.
The odd part is that i took it to a mechanic and he said there was a bit of oil leaking through the bottom portion of the engine but it wasn't bad enough to make a difference.
Old 04-06-2014, 12:17 PM
Quickshift_C5
Quickshift_C5's Avatar
"Got my oil changed"
I am assuming you had someone do it for you then? Are you absolutely sure they filled it all the way/put enough oil in? Did you check it yourself?
Old 04-06-2014, 12:31 PM
Boh
Boh's Avatar
Yea he put a bit over 6.5qts.
Old 04-06-2014, 12:39 PM
01vette360
01vette360's Avatar
Have you checked to see if oil is leaking anywhere? Under the car did you look/feel for dripping oil on pan, block, exhaust.... Check oil filter for tighten/leaks??
Dealer change your oil or a buddy do it for a case of beer kind of thing?
Old 04-06-2014, 12:42 PM
Boh
Boh's Avatar
Originally Posted by 01vette360
Have you checked to see if oil is leaking anywhere? Under the car did you look/feel for dripping oil.... Check oil filter for tighten/leaks??
Theres no oil under the car. But there is a bit by the oil pan. Not sure how i should go about solving this.
Old 04-06-2014, 12:57 PM
01vette360
01vette360's Avatar
If you can get under the car and try to trace the oil dripping down or feel around under there... Tuff to burn thru all that oil in that short period of time.... If you did your car would have looked like a choo choo train coming Down the tracks.....
Old 04-06-2014, 01:16 PM
Boh
Boh's Avatar
Thanks for all the help gentlemen. Tomorrow morning ill take her to the mechanic so he can check it out.
Ill keep you updated.
Old 04-07-2014, 07:27 PM
Boh
Boh's Avatar
The filter was coming loose and thats where we suspect the leakage was from. Got the oil drained all the way and got me some new oil and filter.
Ill be checking it all week to see whats up.
Old 04-07-2014, 08:38 PM
01vette360
01vette360's Avatar
Wow... Was that a dealership? You almost had a new motor!!
Old 04-07-2014, 08:51 PM
MY03C5Z
MY03C5Z's Avatar
Glad it wasn't anything serious. That's one more reason I change the oil in all of our vehicles myself. Not to mention stories of oil lube places not even replacing filters, loose/stripped plugs etc....
Old 04-07-2014, 09:04 PM
PeteZ06
PeteZ06's Avatar
Called it Glad it was a simple fix!
I go to a local oil/lube place but totally trust them... a bunch of younger guys that are mostly all into racing and I talk with them and watch them as they change my oil... its not worth the mess in my garage and crawling under my car to save $20.
Old 04-08-2014, 07:18 AM
Boh
Boh's Avatar
Its a small shop. I decided to go for a quick stop before the weekend started. Read a few reviews and they were all 5 stars. That was probably before their filters fell off.
Never going there again, thats for sure.
Old 04-08-2014, 07:21 AM
Boh
Boh's Avatar
I think i just need to find myself a reliable shop. Theres not many trustworthy shops around here. They just want to take your money.
Old 04-08-2014, 07:24 AM
Boh
Boh's Avatar
Thanks again guys. Glad i could solve it without flattening my wallet.
To Low oil after a week
Quick Reply: [Z06] Low oil after a week
