TPMS issue
Old Apr 6, 2014 | 04:18 AM
Frank4202's Avatar
Frank4202
Default TPMS issue
Recently got new wheels on the car with 4 TPMS sensors. Ive programmed the old sensors before so Im familiar with the procedure. Cant get the horn to chirp on the LF wheel when starting the programming. Pressures show "_____". Any ideas?
-Sensors are rebuilts for a 97 (Car is a 97)
Old Apr 6, 2014 | 05:15 AM
Narco944's Avatar
Narco944
You using a big enough magnet?
Old Apr 6, 2014 | 05:35 AM
Frank4202's Avatar
Frank4202
I actually ripped one off my magnetic tool tray. Same one I used and worked with the OEM wheels
Old Apr 6, 2014 | 08:21 PM
Frank4202's Avatar
Frank4202
I ended up doing a "fob training" and was able to get them all to chirp aside from the LR. After trying for an hour, I did a fob training again and now cant get the the two front tires to chirp. What gives?
Old Apr 6, 2014 | 08:30 PM
C5RClone's Avatar
C5RClone
I had similar issues but just kept trying and it finally worked.
Old Apr 6, 2014 | 10:33 PM
20roadking11's Avatar
20roadking11
I had new TPMSs installed when I had new tires mounted. I drove home & programmed them with no problem. A couple of months later they quit working. I tried to reset them & had all reset except the right rear. I have attempted to reset them a half dozen times & still the same results,right rear will not reset. I order a new one. It should be here this week. I blame it on Gremlins.lol
Wayne
To TPMS issue
