[Z06] transmission problem?
Old Apr 6, 2014 | 06:25 AM
Ferg03 Z06's Avatar
Ferg03 Z06
Default transmission problem?
I was driving my Z the other day and while changing gears from 4-5 it would slide all the way over and attempt to go into reverse. I was just cruising around with no "spirited" driving. I did not grind the reverse gear because I have been driving a 6 speed long enough..4th car with a 6 speed, and realized that it was not in the proper position for 5th.
Im sure that this issue has been addressed somewhere but I just couldn't find it. Is this a known issue or just a random fluke?
It did it 2 seperate times on this particular day and I probably changed gears from 4-5 20 times or so this day.
Old Apr 6, 2014 | 07:31 AM
emmett77's Avatar
emmett77
I had the same issue (but I was grinding against reverse a few times before I just skipped going to 5th gear for a while). I had my reverse lockout solenoid replaced. No more grinding going 4th to 5th.
Old Apr 6, 2014 | 08:11 AM
Ferg03 Z06's Avatar
Ferg03 Z06
I knew there was supposed to be a lock out. This is the 4thcar with a T-56 transmission...I know this is a MN12 but you know what i mean..and the only one to ever do it. Car only has 32,xxx miles. I dont really want to pay to have the solenoid replaced...saving for a supercharger kit!! Is there any other reason it may be doing this and only occassionaly? Thanks in advance
Old Apr 7, 2014 | 12:48 PM
emmett77's Avatar
emmett77
I was told, if not the reverse lockout solenoid it could be internal (bent fork or bad synchro). Much more expensive to repair. I'm glad my problem was the solenoid!
To transmission problem?
