C6 Shifter
Old Apr 8, 2014 | 08:05 AM
rocket71's Avatar
rocket71
Default C6 Shifter
I am wanting to upgrade my C5z shifter to a C6z shifter. I found a two threads with part #'s but they are not coming up as correct at gmpartwarehouse. Can anyone provide me with the part #'s or a link to purchase what I need? Thanks!
Old Apr 8, 2014 | 09:02 AM
Navybluevette's Avatar
Navybluevette
St. Jude Donor '12-'13-'14-'15-'16-'17
There is no longer two different shifters for the C6 Zo6 and standard, they switched to a single shifter in 08 and that is P/N 25823572 (which is the number for the standard..
Old Apr 8, 2014 | 01:09 PM
rocket71's Avatar
rocket71
Thanks, so I just need that part # and then the shift ****, is that correct?
Old Apr 8, 2014 | 01:47 PM
Bluefire's Avatar
Bluefire
Be aware that the new shifter has a plastic twist-lock ring to attach the boot to the shifter.
Old Apr 8, 2014 | 02:27 PM
Navybluevette
That is correct.
Or you can use a zip tie.
Old Apr 8, 2014 | 03:25 PM
Slow Z06's Avatar
Slow Z06
Another option to the zip tie is to pull the leather up, place a small rubber band over it, fold the leather over the band and hot glue it. Once dry just pull that part up over the shifter handle.
To C6 Shifter
