Pulled codes..
Old Apr 9, 2014 | 08:42 PM
DA1984VETTE's Avatar
DA1984VETTE
Default Pulled codes..
I decided to pull codes today after changing the battery. The car hasn't been driven since the first week of November. These are the codes I got:
28-TCS - Traction Control System: C1255H
40-BCM- B0503H and B0508H
I looked up the codes and the C1255H is EBTCM Internal Malfunction
And the B0503H is RH DRL Relay Circuit
B0508H is LH DRL Relay Circuit
Are these codes I should be leary of or should I drive the car and check the codes again? Are the B0503&8 Codes are them the driving lights circuit? Any help would be appreciated and thanks for looking.
Old Apr 10, 2014 | 09:00 AM
DA1984VETTE
Thanks 8Vette7 i figured you would be one that would respond..Thanks again much appreciated.
