Code pattern
Old Apr 10, 2014 | 10:22 AM
riverguy's Avatar
riverguy
Cruising
Default Code pattern
I'm looking at a 2003 C5. It is low mileage, and appears to be in nearly perfect shape. Everything I've tested works, except the driver's door lock, which will UNlock from the switch, but not lock (?).
It has no current codes, but was showing the following history codes.
Anyone see a pattern I should be concerned about?
Loss of contact with the doors indicate a wreck or major trouble in the past?
Thanks, as always, for all the help on the forum.
BCM
B4032H
B0502H
B0503H
B0507H
B0508H
B2528H
B2587H
B2592H
B2593H
B2809H
LDCM
B2282H
B2284H
U1064H
RDCM
B2283H
B2285H
U1064H
SCM
B0851H
RFA
U1000H
U1255H
Old Apr 12, 2014 | 11:04 AM
riverguy's Avatar
riverguy
Cruising
Good point about checking after a drive, and BEFORE switching the engine off. This makes perfect sense. It should have been obvious, but evidently I'm none too bright. I'm pretty sure that this isn't covered in the (otherwise excellent) DIC instructions I found on this forum, or else I overlooked it.
I think I'm OK on the steering column, as it doesn't seem to lock at all, and the wheel can be turned when the ignition is off. Does this sound correct?
Thanks!
