Plugs/wires
Old Apr 12, 2014 | 07:06 AM
memmer's Avatar
memmer
Default Plugs/wires
Can someone give me an idea what it costs to have plugs/wires replaced in my stock 2001 base A4 vert.in a shop.Thanks for looking
Fred
Old Apr 12, 2014 | 07:10 AM
frsr06's Avatar
frsr06
Fred
Did it about 2 months ago - $800 at a Chevy dealer
Old Apr 12, 2014 | 07:56 AM
baxsom's Avatar
baxsom
Jumping jesus on a pogo stick 800 bucks!!!! GM red wires and 8 NGK Tr5 plugs will run you 60 bucks tops. Spend an hour and do your own. You might at worst bust your knuckle on the back ones.
Old Apr 12, 2014 | 09:40 AM
Chilliwack vettes's Avatar
Chilliwack vettes
Old Apr 12, 2014 | 11:32 AM
JR-01's Avatar
JR-01
Plugs and wires for 800 bucks? Are you sure? That's nuts.
Old Apr 12, 2014 | 12:02 PM
bjones7131's Avatar
bjones7131
Not me, along the same thread, has anyone ever been able to tell a big difference when plugs and wires were replaced. I haven't under normal routine maint., if you have a real noticeable bad skipp then u will probably see improvement. Am i n felt field on this??
Old Apr 12, 2014 | 12:09 PM
NorthEnco's Avatar
NorthEnco
Default 10 hours
800 dollars , cripes that's 10 hours of labor at 80 per hour......
1.25 hours per plug
Old Apr 12, 2014 | 12:27 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Oh man!!!! That is priceless!! I've never heard that saying before and laughed so hard at the mental picture it conjured up that I am wiping tears away so I can see to type this!!!!!
Thanks man, you made my day!!! Every time I visualize it, I start laughing all over again!!
DSTURBD
Old Apr 12, 2014 | 12:48 PM
Six7390gt's Avatar
Six7390gt
2021 C5 of the Year Finalist - Unmodified
St. Jude Donor '25
I've been searching, found lots of info. Seems easy enough to do if you can get past number 7, I'm going to go ahead and replace my own. I see a spark plug wire puller is desired and MSD wires and NGK irridium plugs are popular. Anyone know of a good thread on choosing and replacing them?
Old Apr 12, 2014 | 03:06 PM
Good Lord they saw you coming.
To the OP - do the swap yourself - with a good socket set and some extent ions/swivels, it is a pretty easy job.
Old Apr 12, 2014 | 08:55 PM
laurent_zo6's Avatar
laurent_zo6
St. Jude Donor '15-'16-'17-'18-'19-'20-'21-'22
New owner so still learning... I read a few posts where it was mentioned that some of the spark plugs are hard to remove. Just curious to what is the problem. Lack of space to remove them or ??? And do you have any tricks to make the removal easier. Thanks.
Old Apr 12, 2014 | 08:57 PM
frsr06's Avatar
frsr06
Yep - dealer pricing - I was screwed. Next time I'll do it myself.
Old Apr 12, 2014 | 09:49 PM
DSTURBD's Avatar
DSTURBD
Senior Member
Cruise-In V Veteran
Had a similar experience last week. Right now, I don't have the required equipment to change the oil myself (jack, ramps, stands, etc.), so I have been taking it to the dealership as I live in a very small town. This last time, I told the service writer to be sure and have them check the coolant level as the low coolant warning came on once when I was on a severe grade. They soaked me for a half hour of troubleshooting time to check it out, $44.50, and said, "The sensor is probably going out. We can fix it for $208.63." Yeah, thanks, but no thanks!!
Now does anything I said - Please be sure to check the coolant level - sound like I said, "Yes, please spend an inordinate amount of expensive shop time checking out a non-existent problem on my car for me"?
Oh and they also wanted to do the following:
Injector flush..................$169.44
Trans flush.....................$195.92
Fuel filter replace.............$263.09
Serpentine belt replace.....$298.81
I don't remember putting a sign on my forehead that day that said "Duh, I'm too stupid to live!! Please bend me over and put it to me good!!!"
I ended up doing the belt and tensioner myself for about $100.00 in parts and still thought it was a bit steep.
There's a reason they are called Stealerships!!!!
DSTURBD
Old Apr 12, 2014 | 09:55 PM
barkingowl's Avatar
barkingowl
Cruise-In IV Veteran
Cruise In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Frsr06 what dealership did you go to?
Old Apr 12, 2014 | 09:59 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
WTH!
NGK TR55 plugs (Gapped at .055)
MSD Wires (Your choice of color)
Cost you under $150 easy and you can simply do it yourself!
Here is a step by step with pics you can follow:
http://www.iammoon.com/c5tech/c5_plugs.htm
Thanks,Matt
Old Apr 12, 2014 | 10:02 PM
Clancy209's Avatar
Clancy209
Use a Swivel ratchet, remove drivers side check valve, move brake booster line over. Not a hard job at all.
Old Apr 12, 2014 | 10:06 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
OP, so sorry you got the screwed routine. You should go back and ask for fair treatment or that dealer will never see you car again! They should make it good or lose you forever!
MSG or GM Reds, plugs are a hot debate. Don't fret to much! Just drive!!!!!
To Plugs/wires
Old Apr 12, 2014 | 11:28 PM
madmatt9471
http://www.summitracing.com/search?S...rd=ngk%20tr-55
Iridium NGK
http://www.summitracing.com/search/s...=ngk%20iridium
MSD Wires (Your choice of color) these are red
http://www.summitracing.com/parts/ms...ette/year/2001
All Colors and choices of wires:
http://www.summitracing.com/search/m...rder=Ascending
Thanks,Matt
Old Apr 13, 2014 | 05:35 AM
baxsom's Avatar
baxsom
I got yelled at by a vendor here a few years ago for expressing my displeasure of the MSD wires but since I saw them recommended I'll do what I did then and go over my experience with them.
GM Reds are cheaper but I had read about how awesome the MSD ones are so my first attempt was them. The metal clips were so far into the boots that I had to pull them out with a set of needle nose pliers to get them to hit the plugs. It was a very soft engagement and it took many P0300 tries to get them all on correctly.
I replaced them with a set of GM reds. With no pliers necessary each one snapped on clicking very loudly twice indicating that they were securely on both the plug and the coil. When I combine this with the bad reviews that the MSD coils get on top of my other bad experience with a MSD-6AL ignition box on my old turbo eclipse I'll stay away from MSD products from now on.
Old Apr 13, 2014 | 08:33 AM
frsr06's Avatar
frsr06
GM dealer in Monroe.
