idler pulley
Old Apr 16, 2014 | 12:22 PM
jmilne1976's Avatar
jmilne1976
Default idler pulley
Need some help. Bought a new idler pulley from autozone, duralast one. but it seems bigger than stock one... When i put it on the car it would not spin freely, am i missing something here??? do i need to add another washer or something? i used original bolt a washed that come off original part. thanks in advance
Old Apr 16, 2014 | 12:32 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
I ordered one from rockauto. Same problem you have. The bearing was the same part number, but the pulley was slightly different. Not willing to wait I pressed out the old bearing, pressed out the new bearing, then pressed the new bearing into the old pulley. Worked like a charm
Old Apr 16, 2014 | 01:09 PM
scarecrowkc5's Avatar
scarecrowkc5
You installed it wrong.
Old Apr 16, 2014 | 01:21 PM
jmilne1976's Avatar
jmilne1976
Installed it with same bolt and washer that came off the original parts but it sits against block and won't spin.
Old Apr 16, 2014 | 02:20 PM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
Had the same issue a few weeks ago... no resolution and ended up putting the stock idler back on for the time being
Old Apr 16, 2014 | 05:33 PM
scarecrowkc5
I had one go bad and the tech who worked on my car said that the new pulley was bad and he showed it to me. Everything looked fine outside of the scratches it had on the back side. He called and got another one, then installed it. Later I was looking at the one he replaced and the scratches weren't there. So he did install the first one and didn't fess up to it.
So it had something to do with the install, I wasn't there so I can't tell you what he did.
Old Apr 16, 2014 | 07:37 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
I also recently purchased a new idler pulley from rock auto. The replacement part came with a different washer. Bolted the new part with new washer on with the old bolt and no problems.
Old Apr 17, 2014 | 11:13 AM
Narco944's Avatar
Narco944
Don't use the front washer from the old idler pulley. Just use a generic washer. It'll work fine.
Old Apr 17, 2014 | 03:37 PM
schaffer C5's Avatar
schaffer C5
I just got the idler asy. From summit and said screw the pully.
Old Jun 9, 2014 | 10:01 PM
scarecrowkc5
Ok, I figured it out now.
I replaced the a idler pulley on the drivers side tonight. It was worn out because I could spin it freely with a flip of my finger. The new one will not do that.
The problem was when the new pulley was installed with both the front and rear dust shields it would lock up. The solution is to not use the rear dust shield and only use the front one. Now after tightening it I can spin it with my hand.
I think that you need to use the front dust cover so the bolt with set correctly. The bolt only goes in so far and you need the distance created by the thickness of the dust cover.
I hope this helps anyone who searches for this problem.
To idler pulley
