Let's see your sub boxes!
Old Apr 18, 2014 | 10:21 AM
VJD2's Avatar
VJD2
St. Jude Donor '11
Default Let's see your sub boxes!
I'm getting ready to install a sub box but wanted to see the fit and finish of various vendors boxes.
Post up some pics of your sub box, who made it and your opinion of it.
Also where do you put your amp?
Thanks!
Old Apr 18, 2014 | 10:29 AM
calivette805's Avatar
calivette805
Everyone usually runs the center spare compartment box
Old Apr 18, 2014 | 11:16 AM
StrangelovesM6Vert's Avatar
StrangelovesM6Vert
Here's my setup
I bought the box on ebay
The amps are mounted on rubber posts from Grainger
Old Apr 18, 2014 | 11:30 AM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
Not the best pic, but a single 12 has been plenty for my needs.
Old Apr 18, 2014 | 11:39 AM
Narco944's Avatar
Narco944
Is that the cargo mat laying over the top of the sub?
Old Apr 18, 2014 | 12:06 PM
skydiven4fun
It is, I don't put the hard cover on but I do let the cargo mat lay on the top, helps protect and hide it.
What you don't see is a spacer I made out of hard foam to give it about 1 1/2 inches of space to breath.
Old Apr 18, 2014 | 05:19 PM
Na4now's Avatar
Na4now
I've gone back and forth on whether to install a couple amps, some coax's and a sub. I have plenty of stereo stuff from mild to wild, but the idea of adding the extra weight bothers me.
Hell, right now I have to crank up the volume (stock bose) to try to make out what song is playing. My full exhaust w b&b bullets is loud and droney. Couldn't imagine the guys that run straights.
Old Apr 18, 2014 | 05:47 PM
Chilliwack vettes's Avatar
Chilliwack vettes
Stealth box by Dennis at Double D, amp bought private mounted behind the waterfall.
Peter
Old Apr 18, 2014 | 06:08 PM
racebum's Avatar
racebum
JL 6w3 coupled with 6.5" c2 separates in the doors and a phoenix gold tantrum 400.4 running it all
sub box weighs less than 3lbs and is made out of pine. i really wanted to keep the weight down but add a little rear fill. with cabin gain i'm nearly flat to 40hz. isn't the loudest system but it's light and sounds decent
Old Apr 18, 2014 | 08:08 PM
algZO6's Avatar
algZO6
Old Apr 18, 2014 | 08:35 PM
10sec89's Avatar
10sec89
Home made bandpass.
To Let's see your sub boxes!
